Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 10-12-2010, 12:09 PM
  #9901
Eirik's Avatar
Originally Posted by M3dreamin2008
Has anyone tried anti-dive up front and rear kick up? I know it might be silly, but i was just curious.
I have tried it several times, but I always go back to have the arms flat as I am just as fast or faster.
I know Jilles and Viktor often runs with front anti-dive, so you should just try and see if it makes you faster or more comfortable with the car.
Running rear kick up was something I did not like at all, made the car strange to drive.
I did run with pro squat in the rear at a race some years ago, and it made my car 2/10th faster, got lots of on power steering. worked really well together with a one-way.
Eirik is offline
Old 10-12-2010, 04:06 PM
  #9902
CraigM's Avatar
Trader Rating: 34 (100%+)
I ran my smokem fx deck last night and wow what a difference. More steering and more rear grip compared to the tamiya lipo chassis and it changed direction better too
Originally Posted by Arahawak
Hopefully i dun offend any body here..
Do you guys know if an xray gear diff fits the 416x? and that it has the same teeth?
No the xray is 38t
Originally Posted by kschu
anyone tried the marc additive??
It works good on some surfaces, other times it can make the car a bit loose. I normally prefer tweek
CraigM is offline
Old 10-12-2010, 06:52 PM
  #9903
kschu's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Eirik
I really like it, I set my fastest laps with this additive on my home track.
can share how your apply the additive?
kschu is offline
Old 10-12-2010, 06:56 PM
  #9904
Senna Racing's Avatar
Default Tamiya T-Shirts
Tamiya t-shirts for sale $20 Aus Dollars plus postage
available in M to L and xl to xxl
Tamiya TRF416 / TRF416WE / TRF416X-trf-white.jpg
Tamiya TRF416 / TRF416WE / TRF416X-trf-white-back.jpg
Tamiya TRF416 / TRF416WE / TRF416X-picture-022.jpg
Tamiya TRF416 / TRF416WE / TRF416X-picture-023.jpg
Senna Racing is offline
Old 10-13-2010, 12:11 AM
  #9905
Arahawak's Avatar
Trader Rating: 32 (100%+)
Originally Posted by CraigM
No the xray is 38t
Thanks CraigM. Do you know then if there is alternative gear diff that we can use besides Spec-R?
Arahawak is offline
Old 10-13-2010, 12:59 AM
  #9906
TryHard's Avatar
3Racing make one too. I got an example of both when i picked up my latest X
As for additive, the Marc stuff has been on my table all year, but out of the three options (MarcR, Tweak and CS) I'vemostly ended up using CS, seemed to tail off less in a run...
HiH
Ed
TryHard is offline
Old 10-13-2010, 02:12 AM
  #9907
Arahawak's Avatar
HiH
Ed
Thanks. I guess my question next is between the 3Racing and Spec-R, are they really any difference? in terms of built, quality, durability and ease of assembly when changing oils?
Arahawak is offline
Old 10-13-2010, 06:33 AM
  #9908
crabboy's Avatar
Trader Rating: 58 (98%+)
Ive tried both and the Spec R is by far better than the 3 Racing geardiff.
The 3 Racing diff always felt tight and notchy when built and the large gear is a VERY tight fit onto the shaft so tying to remove it out from the gear housing is near impossable.
The Spec R is made a bit cheaper but seems to be just as good and with the new X rings the leaking is now fixed.
Rhys
crabboy is offline
Old 10-13-2010, 07:51 AM
  #9909
Eirik's Avatar
I clean the tires with FX II or motorspray, then apply a thin even coat over the whole tire (also sidewalls) for about 40min.
If it's "cold" (below 25C) I will use warmers set to 50-55 deg.
Good Luck.
Eirik
Eirik is offline
Old 10-13-2010, 01:58 PM
  #9910
Does that mean you are racing Tamiya again?
stuartb is offline
Old 10-13-2010, 04:38 PM
  #9911
CraigM's Avatar
Agreed, a lot of guys I race with have been breaking rear belts with the 3R diff too, I had one snap after 2 runs
CraigM is offline
Old 10-13-2010, 05:10 PM
  #9912
Stilo's Avatar
Ive broken 3 rear belts in like 50 heats with Spec-R diff, once the belt snapped and twice I stripped the belt and the center pulley. Waiting for the bigger aluminum center pulley in 417.
My TRF Lipo chassis is working great, still nothing to complain, only that after buying it the 417 is coming too soon...
Stilo is offline
Old 10-13-2010, 09:20 PM
  #9913
Arahawak's Avatar
Why will snap the belts? Would lessen the tension of the belts help?
would the bigger center alu pulley help in preventing belt snaps?
Sorry for so many questions.. trying to learn the car.
Arahawak is offline
Old 10-13-2010, 10:01 PM
  #9914
geeunit1014's Avatar
Trader Rating: 14 (100%+)
The rear arms are pretty much run flat everywhere, the front anti dive is really a feel thing. Personally, I like the feel with antidive much better, especially in lower bite conditions. The only place I havent liked it is at The Coliseum, but the traction there is so ridiculous no standard setup stuff works there. Some like it, some dont, you just have to try it and see.
geeunit1014 is offline
Old 10-13-2010, 10:06 PM
  #9915
syndr0me's Avatar
I killed a rear belt with the Spec-R (w/5.5) too. I made the rear belt tighter than usual (two clicks on the cam from center) and that seemed to fix it. The drive train doesn't bind up either.
syndr0me is offline
