Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 10-11-2010, 07:16 AM
  #9886
Xchange's Avatar
Trader Rating: 10 (92%+)
basically, i ran geared diff with 1000cst for 1 run
and come back to the ball diff because with my lack of traction, gear diff send too much power to rear wheel and my car made a 360deg on place
about the steering brace, i removed the upper screew, they changed nothing, i rescrewed and no better result... the car globaly did'nt responding from the very first run.
I tried the with springs on front, yellow on back and no change...
Xchange is offline
Old 10-11-2010, 09:59 AM
  #9887
Johnny Wishbone's Avatar
Originally Posted by Xchange
My springs are dark blue on front and yellow on rear. Oil i started with 45wt to all and put 55wt on rear to give a bit more rear traction on high speed turn.
You have your oil split wrong most run thicker in the front and lighter in the back, right numbers just wrong ends of the car.
Johnny Wishbone is offline
Old 10-11-2010, 10:26 AM
  #9888
Xchange's Avatar
Yep i know, the fact is if i put 55 in front, i lose the end on low speed corners...
I will try to put back the original chassis to see what happens... This afternoon i was at 2clicks to buy a TCX lool
Xchange is offline
Old 10-11-2010, 10:32 AM
  #9889
You should try and post a setup sheet of what your running the guys like Art and Syndrome can get a better look of what your doing.
If the oil split is that touchy I'd run the same front and back and adjust spring rate and shock angle, might look at the bars in the car as well. Have you tried any anti-dive. Really need the setup sheet for a starter.
Old 10-11-2010, 02:19 PM
  #9890
TryHard's Avatar
I agree with Johnny here, that oil split sounds all wrong... I have run 5wt heavier in the rear before, but in all honesty never liked it!
If you say it washes too much with 55 in the front, try 50 all round!
And if you want to get the high speed steering back, try leaning rear shock in, or even medium rear bar.
HiH
Ed
TryHard is offline
Old 10-11-2010, 02:57 PM
  #9891
artwork's Avatar
Trader Rating: 88 (100%+)
That is because the balance of the car is all off...Please post your setup or just try one of the team drivers setups...
TCX is not the answer...you own the best car ever made...why step down?
These should get you close...
Pavement setup: http://projectgreenracing.com/PGR/Re...X%20Norcal.pdf
Carpet Setup: http://projectgreenracing.com/PGR/Re...%202010%20.pdf
artwork is offline
Old 10-11-2010, 03:23 PM
  #9892
M-Technic's Avatar
Trader Rating: 15 (100%+)
Hello,
This week, i ran my new freshly builted 416X with a Smokem 416FX chassis.
The car is perfectly balanced and weigth is equal left/right forward and backward.
All the stuff is new, tire glued and EPA is correctly setted.
And from the first time i put the car on the track, the 416 lose the rear left and right but left is much violent than the right but basicaly, no traction on the rear.
No tweak on the chassis and no pin bented.
The main problem is, the car dosent react to my setup change.
What i think is the smokem chassis is have too much flex.
Anybody have a similar issue ?
thanks
What is your track's traction like? You might want to go with lighter oil all the way around, especially in the rear. Like 35wt all the way around. 3 hole pistons.
M-Technic is offline
Old 10-11-2010, 04:17 PM
  #9893
CraigM's Avatar
Trader Rating: 34 (100%+)
Here is Jilles Groskamp's base asphalt setup
http://www.rctech.net/forum/5628027-post43.html
Here is what Jilles recommends for running in low grip
Originally Posted by JGH
I recommend the following changes to change while running on low grip surface.
- Camber, little less, 1 degree
- Kick up rear, this helps on power traction, 1mm/0mm
- less droop, more uptravel, try 5mm/4mm
- more toe-in
- 30W shock oil, with soft springs
If your car does not work with the base setup and the low grip changes then you are doing something wrong
CraigM is offline
Old 10-11-2010, 04:41 PM
  #9894
Xchange's Avatar
Thanks everybody for your help,
So, about my setup, is the base setup with 45wt oil and 2hole from external in front and 1hole before the last in the rear.
All the rest is out of the box
Tonite, i tried to put the stock chassis and the car come very comfortable to drive!!!! Fast and easy to drive!!!!
So i think my problem come from the transport from australia to switzerland with my smokem lower deck.
The test are done on the same track tonite with the same low to medium grip.
I put back on the smokem chassis after the test with the original chassis and the problem started again and the car turn a lot more in one side and generaly the end tend to came off, on high speed off power corner.
Any one had same issue with his smokem chassis(or after market chassis?) i precise, i m do not telling smokem product are ditch, just seems to have my chassis squeezed during the transport)
Xchange is offline
Old 10-11-2010, 05:55 PM
  #9895
Suspended
I just pre-ordered the TA05V2-R, and got the pdf manual via TamiyaUSA.
I am shocked. What other TRF416 parts can I use on this car? It's coming out of the box w/ TRF416 front hubs, hub carriers, and rear hubs - what else can I use? A TRF center pulley/diff please - LOL!!!!
No. Seriously. The TRF415 and 416 susp parts are suddenly melding together in my kit-to-be
dragnse7en is offline
Old 10-12-2010, 01:22 AM
  #9896
Arahawak's Avatar
Trader Rating: 32 (100%+)
Hopefully i dun offend any body here..
Do you guys know if an xray gear diff fits the 416x? and that it has the same teeth?
Arahawak is offline
Old 10-12-2010, 05:44 AM
  #9897
ark
Have you put the chassis on a flat piece of glass or board and checked for rock? Maybe it is tweeked.
ark is offline
Old 10-12-2010, 06:26 AM
  #9898
kschu's Avatar
Trader Rating: 16 (100%+)
anyone tried the marc additive??
kschu is offline
Old 10-12-2010, 07:37 AM
  #9899
Has anyone tried anti-dive up front and rear kick up? I know it might be silly, but i was just curious.
M3dreamin2008 is offline
Old 10-12-2010, 11:48 AM
  #9900
Eirik's Avatar
I really like it, I set my fastest laps with this additive on my home track.
Eirik is offline
