Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 01-10-2008, 06:05 PM
  #976
quantum's Avatar
what is the final word on the suspension blocks - are they the same on the 416 as they are on the 415?
after looking at post #479 on pg 16, they look the same measurements, but the discussion from owners was inconclusive...
quantum is offline
Old 01-10-2008, 06:19 PM
  #977
JimmyMac's Avatar
Same dimensions, but bulked up a bit around the screw holes. Plus made so that you could flip all the blocks upside down with a 3mm shim. Before you could not do that with an A block. Now you can. Anyways, the 415 blocks work on the 416 no problem.
JimmyMac is offline
Old 01-11-2008, 12:57 AM
  #978
TryHard's Avatar
Previously if you wanted to use B, C, or X blocks on the front rear mount (upside down), you would need to flatten off the block a little to provide a solid mounting, and then use 5mm worth of shims.
The new blocks simply appear to be a revision, with the spacings on the top similar to thoose first seen on the XA, XB, XC, and XD blocks.
HiH
Ed
TryHard is offline
Old 01-11-2008, 05:20 AM
  #979
5tylez's Avatar
Suspension arm question:
what are the benefits of using short arms with longer blocks, over long arms with shorter blocks on a 416?
I want to try short arms for indoor carpet.
5tylez is offline
Old 01-11-2008, 06:14 AM
  #980
TryHard's Avatar
Just mount the arms on the car anyway, thats what everyone else does.
They seem to help the car react better, and certainly seem faster indoors.
HiH
Ed
TryHard is offline
Old 01-11-2008, 06:50 AM
  #981
5tylez's Avatar
Thanks Ed,
do you have a setup I can start with using the short arms?
5tylez is offline
Old 01-11-2008, 07:44 AM
  #982
quantum's Avatar
jimmymac/tryhard - thanks for the clarification on the blocks. good news!
HiH
Ed
i know that is the case for foam tires... rubber tires too?
quantum is offline
Old 01-11-2008, 09:41 AM
  #983
I used
Front: FF: C FR: B
Rear: RF: X RR: E
This will give you 2.5 toe-in at the rear. You can use XA instead if you need 3 degrees. This setup keeps the track width about the same, so you won't have to add spacers for the axel hubs, nor have issues with the dog bone protector rubbing the diff nut. (Maybe with the XA block, you migth have to shave about 0.5 mm though)
Don't forget to readjust your turnbuckles too.
redbones is offline
Old 01-11-2008, 09:44 AM
  #984
TryHard's Avatar
I only race rubbers... so yes
Have a look for coreys setup on here somewhere, or have a look at this one.
Attached Thumbnails Tamiya TRF416 / TRF416WE / TRF416X-carpet-start.jpg
TryHard is offline
Old 01-11-2008, 01:09 PM
  #985
alan1467's Avatar
Anyone know what suspension blocks fit the frt/rear and rear/frt extra holes that are in the chassis? Tried some Cyclone ones and the holes on the chassis are about 2mm wider than the blocks
alan1467 is offline
Old 01-11-2008, 01:49 PM
  #986
syndr0me's Avatar
Trader Rating: 32 (100%+)
http://events.redrc.net/2008/01/gros...ce-in-denmark/
Jilles TQ's the first round of DHI with the 416. That's a heck of a start.
“I will try some mirror changes maybe with the shocks and springs but the car is getting better as the tyres wear down. My big focus for tomorrow is to work on the power. Run time is very close now. I dumped a little at the end but I can see the motor is very dirty and I to clean it. Apart from my car I will help Marc (Rheinhard) with his car as it was not so good so he will try my set-up tomorrow.”
Dang, he's already schooling the boys. I want to try Jilles setup, too! :-)
syndr0me is offline
Old 01-11-2008, 04:55 PM
  #987
TryHard's Avatar
Thoose extra holes are effectively redundant... they were ment for a BD style mounting system (2 seperate mounts, held in with two screws). Tamiya never went that way with the blocks, so not sure why they are there.
HiH
Ed
TryHard is offline
Old 01-12-2008, 08:46 AM
  #988
Hey Ed
Have you try D D front and XA 1E rear with short arms yet?
Cruisaaja is offline
Old 01-12-2008, 03:18 PM
  #989
TryHard's Avatar
Not yet, but may do tomorrow.
Having a quick look at the pictures, seems like the team are running more shims under the rear links, both in and out. Looks like 3mm underneath both.
Seems White/Blue springs AND roll bars are the ticket too.. can't find any pictures with detailing the suspension blocks yet.
Regards
Ed
TryHard is offline
Old 01-12-2008, 11:29 PM
  #990
fadzli's Avatar
Default balance
anyone has this kind of 416 installation? 6 battery, 23t stock tamiya motor, m11 rx, keyence esc. only battery on the right side. i want to ask if need to add more balancing weight on any side. i dont have tool to weigh or balance my 416. tq.
fadzli is offline
