Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 09-22-2010, 06:09 PM
  #9766
mini-dub's Avatar
Trader Rating: 16 (100%+)
Could someone please tell me where to find setups from the team's cars at this years IIC?
mini-dub is offline
Old 09-22-2010, 07:10 PM
  #9767
syndr0me's Avatar
Trader Rating: 32 (100%+)
What's up Weylin? Glad to see you getting back into it. We're still going strong here in Denver.
I was eyeballing the TRF cars (Marc & Victor) at IIC, and they didn't seem a whole lot different than Jilles' Snowbirds setup. Both were running the Spec-R gear diff, however. I ran Jilles' setup while I was there and thought the car was great the whole weekend. It's probably the best place to start on carpet.
http://www.rctech.net/forum/attachme...2106-upper.pdf
syndr0me is offline
Old 09-23-2010, 07:45 AM
  #9768
TryHard's Avatar
Cheers for that, been looking for it...
TryHard is offline
Old 09-23-2010, 11:54 AM
  #9769
mini-dub's Avatar
Glad to hear it! Onroad is picking up here again, though we still dont have an actual permanent facility (that's being worked on though). I wasn't able to make the last race but apparently there were 60+ people . I've been racing mostly 2wd mod the last couple months. Stoked to get this 416x running, thanks for the link!
mini-dub is offline
Old 09-23-2010, 03:10 PM
  #9770
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by kobiwan
is there a chart or guide that tells you what suspension mount yeilds what toe in for the rear?
Also, i heard that giving the front arms a toe out sweep helps with handeling of the car. Has anyone tried this? and if so what suspension mount do you change, the FF or the FR. any help would be appreciated. Thanks
Sweep will give you more mid corner steering, esp in fast sweepers. Normally you would change both front and rear blocks to maintain the same track, so use D/B rather than C/C for example
CraigM is offline
Old 09-23-2010, 03:48 PM
  #9771
Tron's Avatar
Trader Rating: 17 (100%+)
Tron is offline
Old 09-23-2010, 10:38 PM
  #9772
This should help...
File Type: zip
SeanV is offline
Old 09-24-2010, 08:37 PM
  #9773
kschu's Avatar
some tamiya stuff for sell
kschu is offline
Old 09-25-2010, 05:39 PM
  #9774
TryHard's Avatar
Hey all,
Quick Q to those using the TOP driveshaft covers...do you find they rub on the inside of the rear hubs? Any need to remove some material to provide clearance, as it looks like the ones i have here have rubbed a little...
Ta
Ed
TryHard is offline
Old 09-25-2010, 07:07 PM
  #9775
CraigM's Avatar
Originally Posted by TryHard
Hey all,
Ta
Ed
On the losi?
I haven't noticed any rubbin, I did nearly wear through one of the retainers when I accidentally used a too long screw in the front knuckle
CraigM is offline
Old 09-25-2010, 08:26 PM
  #9776
M-Technic's Avatar
Trader Rating: 15 (100%+)
Same here. In fact, I think it cost me a motor last week due to the extra drag in the drive train.
M-Technic is offline
Old 09-25-2010, 10:04 PM
  #9777
syndr0me's Avatar
Yep, mine do that that too. I just file a little out of the inside the hub and it's fine.
syndr0me is offline
Old 09-26-2010, 02:14 AM
  #9778
TryHard's Avatar
On the losi?
umm, no!
On the rebuild last night I only noticed it on the rear, I guess some small bits of dirt have got in between hub and retainer. I will say, make assembling UJ's a piece of pee though
Ed
TryHard is offline
Old 09-26-2010, 02:23 AM
  #9779
CraigM's Avatar
umm, no!
Ed
What the hell, are you back running the Tamiya????
CraigM is offline
Old 09-26-2010, 05:51 AM
  #9780
cheehtae's Avatar
Are you back?
cheehtae is offline
