Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 09-14-2010, 05:22 AM
  #9706
PitNamedGordie's Avatar
Originally Posted by CraigM
I don't think the roll centre value would be the same in those two scenarios, but leaving that aside the second scenario would have less camber gain.
As I suspected the roll centres are completely different, -1.1mm for scenario A, -0.73mm for scenario B, so scenario 1 would also roll more in addition to having more camber gain.
Roll centre calculator:
http://www.rctech.net/forum/5382752-post4285.html
http://www.thard.co.uk/viewtopic.php?f=24&t=145
Originally Posted by 94eg!
Changing roll center via the camber link is very different than the suspension blocks. Raising/lowering the blocks makes very large changes, while altering camber link angle makes a relatively small difference. Here is a drawing I made that illustrates this...
BTW: You may also notice that raising the upper link lowers the roll center, while raising the suspension blocks raises roll center...
Thanks guys! You gave me what I was looking for and then some...
PitNamedGordie is offline
Old 09-14-2010, 01:29 PM
  #9707
any one have setup from IIC of marc rheinardīs car and geardiff?
Zooberg is offline
Old 09-14-2010, 04:46 PM
  #9708
Trader Rating: 47 (100%+)
are these the blue/white springs most you are using on carpet? Thanx
http://www3.towerhobbies.com/cgi-bin...?&I=LXWB01&P=Z
transplantlife is offline
Old 09-14-2010, 05:06 PM
  #9709
Senna Racing's Avatar
no these ones
http://rcmarket.com.hk/product_info....oducts_id=2471
Senna Racing is offline
Old 09-14-2010, 05:16 PM
  #9710
Originally Posted by Senna Racing
ok thanx
Old 09-14-2010, 06:00 PM
  #9711
guys cant seem to find the blue/white springs in the states anywhere. what would be a alternative. it appears the my 416x kit has the blue springs and yellow rears??
Old 09-14-2010, 06:26 PM
  #9712
http://www3.towerhobbies.com/cgi-bin...?&I=LXWB01&P=7
Old 09-15-2010, 12:21 AM
  #9713
Taman's Avatar
Trader Rating: 67 (100%+)
Hi,
is the 3Racing gear diff better for the 416X or the Spec-R?
thanks
Taman is offline
Old 09-15-2010, 03:10 PM
  #9714
IgorR's Avatar
Default Setup
Does anyone have a good carpet setup for the 416X with the Tamiya Lipo upgrade chassis?
IgorR is offline
Old 09-15-2010, 05:35 PM
  #9715
syndr0me's Avatar
Trader Rating: 32 (100%+)
I used Jilles Snowbirds setup with the LiPo chassis at IIC and it was awesome all week.
File Type: pdf
syndr0me is offline
Old 09-15-2010, 09:16 PM
  #9716
Tron's Avatar
Trader Rating: 17 (100%+)
I have a few questions:
How much better is the Lipo chassis that Tamiya makes for this?
Some have mentioned flipping the pulleys, is that possible with the stock chassis? Is the purpose of flipping the pulleys to accommodate the wider lipo battery and improve balance? Is it necessary for someone like me who is getting back into on-road after a 20 year hiatus?
My plan is to run RCGT at West Coast. 911 body, Ballistic 21.5 with a Novak Havoc Pro speed control...will the Havoc fit alright?
Do I have to run a shorty steering servo? Any recommendations?
Tron is offline
Old 09-16-2010, 03:25 AM
  #9717
barts71m's Avatar
Trader Rating: 34 (100%+)
Was this on foam tires????
barts71m is offline
Old 09-16-2010, 05:33 AM
  #9718
Yes Braaah
Jaco handout
Old 09-16-2010, 05:45 AM
  #9719
Pablo Diablo's Avatar
Yes Braaah
Jaco handout
I think they were Jaco Ruberz??
Pablo Diablo is offline
Old 09-16-2010, 06:14 AM
  #9720
kschu's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Taman
Hi,
thanks
both fit well into 416x.
3racing gdiff have slop and can be fix with adding 2pcs axle type shim 0.2mm x 2pcs while spec-r gdiff is leaking but can b fix by replacing with latest o-ring..
so the choices is yours...
SPec-r Gdiff
3racing Gdiff
kschu is offline
