Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 07-27-2010, 08:19 PM
  #9376
I see the price on few HK sites have dropped by $50+. Is there a revised kit coming out with Lipo chassis?
cvccsi is offline
Old 07-27-2010, 10:52 PM
  #9377
LOSI123's Avatar
Trader Rating: 63 (100%+)
Can anyone tell me if this 3 racing part will fit the tamiya spool
http://www.rcmart.com/catalog/rc-trf...h=595_744_1230
also im after the tamiya blades part number
LOSI123 is offline
Old 07-27-2010, 11:56 PM
  #9378
StevenOlsen's Avatar
hi
the 3 racing outdrives works fine
StevenOlsen is offline
Old 07-28-2010, 12:22 AM
  #9379
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Hi Paul,
The part numbers are:
53890 Swing shaft protectors (CVD Blades) 4 per pack
51342 Alum Diff Joint Set (diff outdrives with 4 blades)
9804388 Spool Outdrives (delrin part)
Any 5 digit part number is a regular aftermarket Tamiya part. The part numbers starting with 9 and have 7 numbers in it are kit part numbers and are 'normally' a special order through the Japanese stores.
HTH
DirtyDog3375 is offline
Old 07-28-2010, 01:23 AM
  #9380
LOSI123's Avatar
Thanks StevenOlsen & Leonard
LOSI123 is offline
Old 07-29-2010, 04:39 AM
  #9381
Originally Posted by artwork
When you put shims under your arms you are raising the roll center, and when you put shims under your camber links you are lowering the roll center...
To lower the roll center you would raise the inner camber link position and lower the front arm. You could also lower the outside camber link as well.
Lower
• More on-throttle steering.
• Car is less responsive.
• More weight transfer at front of car.
• Better on smooth, high grip tracks with long fast corners.
To raise the roll center you would lower the inner camber link and raise the front arm. You could also raise the outside camber link as well.
Higher
• Less on-throttle steering.
• Car is more responsive.
• Less weight transfer at front of car.
• Use in high grip conditions to avoid traction rolling.
• Use on tracks with quick direction changes (chicanes).
Hi,
this message is very useful, I wish to receive more information like this in order to understand better what I can do on the 416we set-up in a good manner. Otherwise I changed everything without knowing the effect.
I am asking all of you to integrated more information on the Artwork's topic.
Artwork, Do you have any other suggetions, please?
thanks
lynx75 is offline
Old 07-29-2010, 04:51 AM
  #9382
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by lynx75
Hi,
thanks
Those tips are from the xray setup book
http://www.teamxray.com/teamxray/sho...p?file_id=2525
CraigM is offline
Old 07-29-2010, 05:54 AM
  #9383
Thanks CraigM, the rc/car basement's book for TC.
lynx75 is offline
Old 07-31-2010, 05:08 AM
  #9384
Is the 1050 bearing 10x5x4? Or is it 10x5x3?
home13oy75 is offline
Old 07-31-2010, 06:15 AM
  #9385
dodo's Avatar
CMIIW, I think it's 10x5x5
dodo is offline
Old 07-31-2010, 10:50 AM
  #9386
jonest's Avatar
10x5x4... it's meant for the wheels.
jonest is offline
Old 08-01-2010, 12:42 PM
  #9387
Zooberg is offline
Old 08-01-2010, 01:16 PM
  #9388
RC MARKET's Avatar
this week arrive !
RC MARKET is offline
Old 08-01-2010, 11:31 PM
  #9389
CraigM's Avatar
has anyone tried the Spec R "spring steel" unis yet?
http://www.egrracing.com/shop/spring...16-p-3833.html
it looks like they have pin retainers similar to the TOP pin retainers. I seem to be replacing my uni's a lot to keep the slop out, I'm wondering if these might hold up a bit better than the alloy ones most of us use in the rear
CraigM is offline
Old 08-02-2010, 12:31 AM
  #9390
rc_square24's Avatar
For the diff plates, do you guys use any adhesive to mount them on the outdrive? (round plates with no flat notches)
I used to put tamiya thread lock but they break loose easily with a 3000kv motor. Then a fellow driver told me to just build them without any adhesive but just grease between the outdrive and the plates.
Then I found the same tip from Jilles Groskamp somewhere:
"When I build a diff I first sandpaper the plates on both sides, normally around 500-1000 sandpaper.
I use Tamiya Grease hard to put between the outdrive and the plate. Of course make the outdrive and plate clean with motor spray
Wouldn't it slip if its not glued?
rc_square24 is offline
