Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 06-29-2010, 10:19 PM
  #9151
AZ416's Avatar
Originally Posted by CraigM
Yep. The car changes direction better with the belts flipped and the weight more centred, you also need less weight to balance the car.
Also Jilles has said the reduced width of the chassis allows a softer setup as the chassis touches down less
yea iv already modified my 416x, flipping the belts and having all the weight centered, depending on how much the lipo chassis sells for i might leave it as is.
AZ416 is offline
Old 06-30-2010, 06:10 AM
  #9152
JCarr's Avatar
Can anybody point me to a better bumper for the 416? I'd like one that is a little wider than stock and stiffer.
JCarr is offline
Old 07-01-2010, 08:29 AM
  #9153
syndr0me's Avatar
Trader Rating: 32 (100%+)
They're keeping Marc's car covered the entire time at Worlds.
syndr0me is offline
Old 07-01-2010, 08:36 AM
  #9154
linger's Avatar
It's to prevent Marc from touching his own car and messing up the setup
linger is offline
Old 07-01-2010, 08:40 AM
  #9155
artwork's Avatar
Trader Rating: 88 (100%+)
Maybe Its a Yokomo
artwork is offline
Old 07-01-2010, 08:41 AM
  #9156
LOL
Fastfreddy74 is offline
Old 07-01-2010, 08:45 AM
  #9157
linger's Avatar
Originally Posted by JCarr
...I'd like one that is a little wider than stock and stiffer...
lol!
linger is offline
Old 07-01-2010, 08:51 AM
  #9158
JCarr's Avatar
lol!
The bumper on the car man.
JCarr is offline
Old 07-01-2010, 09:01 AM
  #9159
linger's Avatar
Ok, in that case. Square makes a thick plastic bumper guard that goes beneath the current bumper. It works well at keeping the front suspension intact. If you hit something hard enough, the bumper tends to bend down and it will scrape the ground during cornering. You will have to bend it back. I also noticed that since the bumper is hard, it tends to bounce the car back more when you hit anything. It also makes for a great ramming tool when you feel like hacking someone.
I give it 2 thumbs up.
The part number is STV-106
linger is offline
Old 07-01-2010, 09:14 AM
  #9160
syndr0me's Avatar
If your car stops turning, it's 'cause that plastic piece of crap is dragging on the ground. I'm not a fan like Ling, sorry.
The Parma T2 bumper is a pretty close fit. We usually get those and trim them a bit to fit on the car. It's inexplicable to me why nobody makes a proper hard bumper for the 416. I talked to Chicky about having Parma make one, but that fizzled out I guess.
syndr0me is offline
Old 07-01-2010, 10:09 AM
  #9161
JCarr's Avatar
Thanks for the suggestions guys. i'm not a big fan of those plastic under bumbpers either, but if that was my only choice I'd go with it. My best bet is to stop hittin stuff, but I have a better chance of hitting the lottery.
JCarr is offline
Old 07-01-2010, 12:25 PM
  #9162
jonest's Avatar
could they be running "Non Tamiya" chassis? just kidding..
jonest is offline
Old 07-01-2010, 01:32 PM
  #9163
[QUOTE=jonest;7615709]could they be running "Non Tamiya" chassis? just kidding..[/QUOTE
I was actually thinking the same thing, bet he is testing another make of chassis like the Smokin Extra flex one....... we'll never know as what they run will be kept secret hence some of their setup's just don't work..
blue247carz is offline
Old 07-01-2010, 02:59 PM
  #9164
Most likely all just "mind games"
Bigger Brother is offline
Old 07-02-2010, 04:39 AM
  #9165
CraigM's Avatar
Trader Rating: 34 (100%+)
tamiya top the first two rounds of qualifying!
go Jilles!
CraigM is offline
