Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 05-15-2010, 05:26 AM
  #8866
veecee's Avatar
Trader Rating: 34 (100%+)
Originally Posted by captain stacker
where did you get the spec r gear diff from?
A mate saw them in a HK shop while he was there last week. None of the HK online shops seem to have them at the moment.
veecee is offline
Old 05-15-2010, 07:24 AM
  #8867
dameetz's Avatar
EGR Mart has them when I last browse their site.
dameetz is offline
Old 05-15-2010, 10:04 AM
  #8868
M-Technic's Avatar
Trader Rating: 15 (100%+)
Man I really want a couple of those gear diffs.
M-Technic is offline
Old 05-15-2010, 10:41 AM
  #8869
dameetz's Avatar
Originally Posted by Apex
Has anyone tried the new short black springs item code:42168 (red, yellow, blue) from Tamiya on asphalt? Are these any stiffer\softer than the original red, yellow, blue springs?
I have 'em, judging by compressing it using my fingers, they are softer.
dameetz is offline
Old 05-15-2010, 03:41 PM
  #8870
which diff oil did you use for spec-R diff SPR009-TMY ?
leonardiw is offline
Old 05-16-2010, 06:57 AM
  #8871
TRF4evr's Avatar
Default spec r diff
I have built mine but haven't had the chance to run it. A couple of things I noticed in the build...
All the internal gears are plastic which should be ok in theory. However they are moulded and have some sink marks on the flat side of the gears. In fact the instructions ask you to "polish" them on some sandpaper to ensure a flat surface...
The shaft the small pinion gears ride on is also plastic and moulded as a one-piece cross-shaped part. In other gear diffs, there are normally 2 shafts that cross over each other.
It will be interesting to see how durable it is with the plastic internals. It might be ok since everything is swimming in oil anyway. Other than that, it is a pretty standard issue gear diff. It is nice and smooth. Can't wait to test it out soon!
hi veecee,
just wondering your opinion on the spec r diff, have you tried running your tc with it fitted....thanks
TRF4evr is offline
Old 05-16-2010, 09:33 AM
  #8872
veecee's Avatar
I should be giving the gear diff a run next weekend. I built the diff with 2000wt oil as a starting point.
veecee is offline
Old 05-16-2010, 01:55 PM
  #8873
cheehtae's Avatar
will this work with the 416 we?
http://www.rc-mushroom.com/product_i...ducts_id=14623
cheehtae is offline
Old 05-16-2010, 08:55 PM
  #8874
Vicko's Avatar
Trader Rating: 14 (100%+)
I may have missed it but where can you get an smoke chassie for the
416?
Vicko is offline
Old 05-16-2010, 09:27 PM
  #8875
PitNamedGordie's Avatar
416?
http://www.smokem-racing.com/Home.html
PitNamedGordie is offline
Old 05-16-2010, 10:13 PM
  #8876
veecee's Avatar
Originally Posted by cheehtae
I remembered checking this out before... And I'm pretty sure the location of the pin holes are slightly different on the 415 spool cup compared to the 416 spool cup.
veecee is offline
Old 05-17-2010, 02:16 PM
  #8877
Default TRF 416 mods, moved motor, belt, center pully
I did It to help the balance on the Car
Alf
alf.skaar is offline
Old 05-17-2010, 02:21 PM
  #8878
syndr0me's Avatar
Trader Rating: 32 (100%+)
Does anybody make rollcenter shims that fit under the 2pc blocks?
syndr0me is offline
Old 05-17-2010, 02:36 PM
  #8879
http://rcmarket.com.hk/index.php?cPa...ort=2a&page=10
This is stock part from Tamiya
Alf
Old 05-17-2010, 03:38 PM
  #8880
geeunit1014's Avatar
I just use regular shims under each of the 2 screws.
geeunit1014 is offline
