Tamiya TRF416 / TRF416WE / TRF416X
#8837
you should run 46mm shafts no matter what blocks you use, their thinner than 44mm so you dont have as much binding and the spool outdrives are less likely to break with 46mm shafts
#8838
need help here, my car (WE) always spins out when coming out of a 180 turn? it's an asphalt track, low grip.
Thanks.
Thanks.
#8839
You could try less droop in the rear
#8840
I thought less droop gave you more on power steering and less rear grip
#8841
On Power droop would be all about the front. If you want less transfer then run less droop in the front for an on power situation.
#8843
#8845
Hi guys,
I just completed my 416x build and had a quick setup question. I'm setting up my ride height and noticed that only on the front the shock collars are not even left to right. My car is balanced left to right and from what I can tell everything is built according to the manual. My concern is that the spring rate will be off as the driver side spring is compressed slightly more then the passenger side.
Driver side:
Attachment 588185
Passenger side:
Attachment 588187
I do not have this issue with my TB Evo 5 MS. All 4 suspension have an even amount of spring compression to achieve the desired ride height. What am I missing?
Thanks in advance.
-John
Driver side:
Attachment 588185
Passenger side:
Attachment 588187
Thanks in advance.
-John
#8846
Tyre warmer
Will you guys be using tyre warmers for racing in an air conditioned hall on carpet? I just bought one of the cheapo Much More Warmer (model MM-TW with 3080 evo controller). What temp should i be setting it up? I ll be using spec tyres of Sweep QTS 32 with FX2 sauce. Can anybody care to make a step by step preparation on what to do to the tyres and the warmers before using it in heats and finals? This is my first time using tyre warmers on my 416x.
#8847
Thanks for all of the responses guys!! I checked and validated all of the recommended setting changes and have discovered that it was indeed chassis tweak. I'm either tightening the screws in the incorrect sequence or applying the incorrect amount of torque. After several tries at tweaking the chassis I managed to get the front level.
#8848
#8849
Hi just wondering what the part numbers for the 416x roll bars. Do they come in soft medium hard?
