Tamiya TRF416 / TRF416WE / TRF416X
#8806
416X stabilizer bars
Ta-5304032 instock !
Ta-5304034 sold out next shipment back in stock
#8807
www.rcmarket.com.hk
If it flakes off very badly then ill order some then,
#8808
huh....where am I....?
painting roll bars?
do I dare ask why?
painting roll bars?
do I dare ask why?
#8809
What spare part or option part needed for box stock 416X to be competitive? What is e first hop up you would buy?
#8810
#8811
spool for most occasions, I dont know why manufacturers insist on selling new kits with one ways. One ways are useless 90% of the time.
#8812
#8813
the 416x comes with spool
unless you get the jap. version which also come with front and center one ways
#8814
#8815
would depend on what class you are going to run
if you were going to run 540 yes but if not go with a spool
but all comes down to personal preferance
A oneway can give you better cornor speed
#8816
Does anyone know the difference between K-parts from the 416 51278
& K parts from 416we 9114053
they both look the same in the picture.
will 51278 fit in the WE without any issues?
the main reason i need either is for the little plastic sway bar holders that fit with coutersink screw to bulkheads.
#8817
hi guys, just wondering if anybody had the same problem. i built my exotek for the 416 yesterday. i have the one with the steel battery holders. anyway, the steel brackets and the upper carbon thingy to hold the battery tape are too high so that the steering cant move properly. i had to reduce the overall steering from 115EPA to 85 epa on my m11x so that the steering wont puch against the steel brackets. very strange design i must say.
has anyone sorted this thing out besides going to the other more rear battery position. i dont like to to that because a moved back battery in my mind reduces steering ?!
has anyone had this issues with the carbon battery holders in the exotek?
#8818
moving your battery pack back will give you more steering off power as the weight is transfared forward
#8819
416X is sold out everywhr. Is it the right time to get 1? or they they phasing out the 416X getting ready for a newer version of 416?
#8820
http://www.speedtechrc.com/store/ebp...id=120&id=8811
