Tamiya TRF416 / TRF416WE / TRF416X
#8793
Those with Smokem chassis, how thick is your chassis? How do find its handling on carpet with rubber tyres?
#8794
Good luck mate! they were rare as hens teeth when the 416 first came out. I've never seen a setup from any of the TRF team that didn't use the kit sway bars tho
#8795
#8797
you should be able to get rid of the tweak by adjusting the link lengths. Check the Jilles video on how it's done. Otherwise tamiya also made white and milk blue sway bar sets so you might be able to source them somewhere. They look a lot better than those poxy coloured ones
#8800
#8801
if your desperate sand down the coloured sway bars with 1000-1200gritt paper, make sure u keep it round and not sand the sway bars flat, and paint them with tamiya black paint, use really light coats and let them dry well...
#8803
How do untweak your chassis if some of the flat screw head are protruding a bit or not even flush with the bottom of the chassis?
#8804
#8805
