Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 04-24-2010, 12:21 PM
  #8746
Trader Rating: 10 (92%+)
Default atomic cvd's
not only are the 1.5mm pins weak, the shaft is weak too. Once the shaft breaks, thats it! Cant buy the shafts alone!
I have 2 sets, one for my tamiya, one for my xray, and in 2 weeks I have broken half of them. I have no confidence in them anymore, not knowing whether I would finish a heat/race!
captain stacker is offline
Old 04-25-2010, 07:39 PM
  #8747
Raman's Avatar
Trader Rating: 85 (100%+)
Default 3.5 FDR
I made a chart that calculates final drive ratios.
Whats the best way to get there.. for instance a 93T spur with 54T pinion or a 76T with 44T pinion..
Would such a spur work or would it be too small?
http://www.amainhobbies.com/product_...-Spur-Gear-76T
Raman is offline
Old 04-26-2010, 12:02 PM
  #8748
Dusttt's Avatar
Trader Rating: 141 (100%+)
what are the major differences with the 416we and the 416x? do all parts interchange? Sorry way to many posts to check it all.
thanks
Dusttt is offline
Old 04-26-2010, 01:07 PM
  #8749
thanks
per TamiyaUSA website:
Motor position has been shifted 1mm to center for optimum chassis balance.
Rear ball differential has been shifted 1.8mm towards the rear to improve rear traction and acceleration.
Wider front bulkhead attachment screw positions and a new lower deck shape enhance the chassis' front rigidity.
Features new carbon 2.25mm lower and 2mm upper decks.
Front pulley features a direct coupling while the center pulley also features a direct drive setup.
Newly designed parts such as lower and upper decks, rear drive belt, front and rear lower bulkhead, motor mount, center bulkhead, and motor mount support included.
stitchy is offline
Old 04-26-2010, 03:40 PM
  #8750
Default upg to 416x from 416we
Need info's on which parts needed to upgrade 416we to 416x
TIA
leonardiw is offline
Old 04-26-2010, 05:31 PM
  #8751
geeunit1014's Avatar
Trader Rating: 14 (100%+)
Anyody know someplace that has the spool drive cups in stock?
geeunit1014 is offline
Old 04-26-2010, 10:10 PM
  #8752
CraigM's Avatar
Trader Rating: 34 (100%+)
I suggest looking a little closer
Originally Posted by stitchy
lower and upper decks, rear drive belt, front and rear lower bulkhead, motor mount, center bulkhead, and motor mount support.
CraigM is offline
Old 04-26-2010, 10:16 PM
  #8753
syndr0me's Avatar
Trader Rating: 32 (100%+)
Have any of you tried the TOP CVD sleeves on your 416? It might require the TOP axle since it has a retaining flange on it, but I think that's a direct fit with the rest of the 416 stuff.
For those of you that haven't seen, rather than secure the CVD cross pin with a set screw, there's a sleeve that goes over that entire portion of the CVD and holds the pin in place. It's retained on one side by being up against the hub, and on the other side it's got a slight flange on it. It's a really slick design, and supposedly helps free up the CVD's somewhat.
In other news, those pics from Japan of all the 416's with the LiPo specific parts on them... is this the earliest after a kit release we've seen new stuff being tested? I've been trying to decide if I want an X before IIC in Sept., but it sure seems like it might have a short life now that Tamiya is finally (and lastly) acknowledging that people haven't used NiMH in 2 years. And man, I love how my WE rotates with the 2.5mm chassis on it in high traction. I might just hang on to it this year and skip the new kit.
syndr0me is offline
Old 04-27-2010, 01:43 AM
  #8754
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Just wondering what the part numbers are for the TOP parts?
Is it this?
http://topracing.net.au/shop/index.p...&productId=594
and this?
http://topracing.net.au/shop/index.p...&productId=457
DirtyDog3375 is offline
Old 04-27-2010, 02:31 AM
  #8755
KWT-NITRO's Avatar
hey guys,
just a small question about Tamiya shocks/dampers, whats different between the stock dampers that come with the 416 kits and the Tamiya 84008 kit??
cheers
Ali
KWT-NITRO is offline
Old 04-27-2010, 02:58 AM
  #8756
Default exotek and lrp 5900 lipo
hi guys, has anybody tested the exotek chassis with the lrp 5900 lipo. i was wandering if the lipo fits no problem or if you had to adjust something?? info greatly appreciated.
vitomon is offline
Old 04-27-2010, 03:14 AM
  #8757
Taman's Avatar
Trader Rating: 67 (100%+)
Has there been anymore feedback on the smoke-em and exotek chassis?
Taman is offline
Old 04-27-2010, 04:58 AM
  #8758
[QUOTE=syndr0me;7325203]
In other news, those pics from Japan of all the 416's with the LiPo specific parts on them... is this the earliest after a kit release we've seen new stuff being tested? I've been trying to decide if I want an X before IIC in Sept., but it sure seems like it might have a short life now ...[QUOTE]
Apologies for cutting the quote down a bit.
I would personally imagine Tamiya may be testing this new chassis and top deck (I can't see anything else on the car that is different) ready for the Worlds in mid July. I reckon that we could possibly then (depending on how the testing and Worlds go!) see a new car around October/November time, ie pretty much in line with the previous years releases.
But that is just a guess really!
Bigger Brother is offline
Old 04-27-2010, 05:47 AM
  #8759
syndr0me's Avatar
Is it this?
and this?
Those appear to be the right parts, yet. I'm not certain if they'll work on the 416, though. I -think- they might, however.
syndr0me is offline
Old 04-27-2010, 12:53 PM
  #8760
andy robson win a big meeting using the smokem chassis on the 416x so it must b good ..
mwoods is offline
