Tamiya TRF416 / TRF416WE / TRF416X
#8581
HK 416,
Did u superglue all chassis opening (battery slots, pulley slots)? Make sure u do.
Yeah, you've noticed sharp eyes, haven't got the chance to do that yet. Will do it soon. ,I'm trying to find the best ESC to use. Do you have any recomendation.
Veecee,
I've placed all my electronics towards the centreline and push the battery out a lil bit (if necessary) to balance the car and it works great. One thing for sure is that my corner speed is slightly faster compared to the ori chassis!
Cheers.
Veecee,
Cheers.
#8582
hi guys, my turn to show my smokem chassis. not sure if its in balance. the car weights 1325 with a LRP 28c 5300 lipo. and a LTC-R (normal weight).
#8584
#8585
#8591
46mm shafts in front make the car understeer and push, this is why the X comes with 44mm shafts. Also is why the X has more steering than the WCE which came with 46mm up front.....
#8593
i never knew the length of the shafts could effect the handling characteristics
#8594
I've used both 46mm and 44mm shafts and it makes bugger all difference. The 46's are nicer on your spool cups though, and Jilles reckons the thinner dogbone smooths out the steering compared to the 44's.
#8595
Sorry but that's not correct, the X has more rear grip due to the battery and diff location...
