Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 02-10-2010, 10:14 AM
  #8161
Akudou's Avatar
I am running a 9t on my chassis on foam tyres, first 3 runs in 2 days i lost the cvd connector. A friend advise me that i should run diffs upfront to avoid that since theres too much traction that the threadlocked pin connector lose itself. Guess its better to run solids on rubber but diffs on foam.
Akudou is offline
Old 02-10-2010, 10:50 AM
  #8162
RC MARKET's Avatar
TRF416X parts
Attached Thumbnails Tamiya TRF416 / TRF416WE / TRF416X-ta-4004071.jpg   Tamiya TRF416 / TRF416WE / TRF416X-ta-4004070.jpg   Tamiya TRF416 / TRF416WE / TRF416X-ta-5304032.jpg   Tamiya TRF416 / TRF416WE / TRF416X-ta-5304034.jpg
RC MARKET is offline
Old 02-10-2010, 01:59 PM
  #8163
Fabricio's Avatar
Default diff question
building the diff one question come to me looking at the manual is not clear, de spring goes on the longe side or in the shorter side of the outdrives?
Fabricio is offline
Old 02-10-2010, 02:02 PM
  #8164
guinnes.s's Avatar
i did buy this
http://cgi.ebay.com/3Racing-Aluminiu...#ht_2205wt_939
stating that are for the 416,but once received i notice that they take the small TA05 size bearing end not the 416 size.
anywere else were i can get the correct one???
plus i do race in a very small track,with very tight turns,and the 416 seems to push wile on power during the turn making the turn more wide that it should.
the travel is at max and using white springs .
any tips?
guinnes.s is offline
Old 02-10-2010, 02:04 PM
  #8165
artwork's Avatar
Trader Rating: 88 (100%+)
The spring goes in the side without the side adjustment hole. I think that would be the short side off of the top of my head.
artwork is offline
Old 02-10-2010, 02:07 PM
  #8166
Fabricio's Avatar
artwork thanks, it is the shorter side, use to the associated one and this one is very different for me but seems quite good too
Fabricio is offline
Old 02-10-2010, 02:10 PM
  #8167
artwork's Avatar
The best diff in the market...I know I have tried all of them
artwork is offline
Old 02-10-2010, 02:15 PM
  #8168
bkspeedo's Avatar
Is there a 2.5mm chassis option or one made by a 3rd party for the 416?
bkspeedo is offline
Old 02-10-2010, 02:21 PM
  #8169
M-Technic's Avatar
Trader Rating: 15 (100%+)
http://www.tamiyausa.com/product/ite...oduct-id=49495
My friend has one on his WE. It is nice to have on high traction asphalt and carpet.
M-Technic is offline
Old 02-10-2010, 02:34 PM
  #8170
hello ..
has just ordered a TF416X instead of Xray T3.
but I need some parts to make different setup on the car.
# which the suspension mount blocks will I have? which come with?
spare parts? c-hubs? drive shafts and so on?
Rule number if someone has?
Zooberg is offline
Old 02-10-2010, 02:49 PM
  #8171
KHoff7's Avatar
Originally Posted by Zooberg
hello ..
It comes with 1C,1C blocks in the front and 1XA, 1E blocks in the rear.
This gives 0 front arm sweep/toe and 3 rear inboard toe. This usually works on most tracks.
KHoff7 is offline
Old 02-10-2010, 02:50 PM
  #8172
RC MARKET's Avatar
Tamiya had 2.5mm Lower Deck
http://rcmarket.com.hk/advanced_sear...lime4soiq749v4
Old 02-10-2010, 05:12 PM
  #8173
Johnny Wishbone's Avatar
hello ..
If you can't find your answer here you should go here, www.thard.co.uk , this site has lots of additional info and rc calculators and gear charts etc.
Johnny Wishbone is offline
Old 02-10-2010, 06:13 PM
  #8174
CraigM's Avatar
Trader Rating: 34 (100%+)
Replace the front swing shafts with steel ones and carry heaps of chubs or switch to the softer IFS ones. Carry a few knuckles, uprights and arms, and keep an eye on wear on the pulleys, particularly the small centre ones.
Also pick up some split blocks to use in place of the block that is flipped over the belt, and 3 D blocks so you can use D/D and XA/D which is the other good combination.
If you're running on asphalt the HPI springs are the pick over the tamiyas, get silver and blue
Hrmm gotta say the photon one is pretty friggin nice. The oversized rings and triangular diff ball holes make for an extremely sensual diff action, and the plastic covers are a heaps better solution than the stickers most of us use
That said the tamiya one is still tops and it'll last a LONG time if you build it right
CraigM is offline
Old 02-12-2010, 06:31 AM
  #8175
Fabricio's Avatar
Default type of pitch
what pitch the car uses? is it 64 or it is a tamiya type?
need to buy some for stock race, which ones do you recomend to have?
i am going to use the orginal spur that came with the car...
Fabricio is offline
