Tamiya TRF416 / TRF416WE / TRF416X
#7880
Thanks for the replies!
I m using a Kimbrough servo saver right now, I have tightened it abit more and it moves around abit less now, but still abit there. Also still abit of slop in the ball ends.
I shaved the top deck down abit yesterday and re-dressed it with some CA, will try it out tonight.
I m hoping that it is the decks that was causing the problem. My TA05 has about the same amount of slop but I dont have any tweaking problems with that...
#7881
Originally Posted by CraigM;
Thanks guys. First outing with the X went pretty well with 3rd place at summernats. I basically ran the kit blocks with the base asphalt setup and didn't change a thing all day. My full setup is posted on Ed's site & I'm looking forward to running the car again
Mc prez great to see you back on TOP
form and only your first outting in a
TRF for a while and instead of bringing
up the rear you were right on pace
it's a shame we don't have a TRF team
here in oz
Maybe we should start our own
#7884
Hye guys,
Pm me 416we setup using rubber tyre n setup using foam tyre size 37 front n rear..
Gona race on 30th n 31st jan..
#7885
#7886
There are a couple of things you can do too help this though;
Use some 4mm shims inbetween the shock body and delrin spacers. This will squish the o-ring slightly and give a slightly better seal. Don't worry about the shim hitting the shaft as the 4mm ones are a perfect fit in the body, and plenty of clearance.
Build the shocks the old way.. If you look at Jiles' shock video, pay close attention when he takes the shock apart, and you'll see he has the o-ring/spacer round the other way to the manual (which is how they used to built). I can't check which way round it is atm, (think spacer then o-ring is the old method) but have a look.
Turning the delrin spacer over so the groove is away from the o-ring will also squish the ring a little more.
HiH
Ed
#7887
How tight do you guys set your diff? I was told to set it as loose as possible without slipping...when I set mine up until its not slipping, I feel it is kind of tight....(in comparison with my friends' t2 and t3, their diff are super smooth) whats the effect of a tight diff? Most of the time my car just break loose in the rear if I m coming into a corner too fast and during abrupt steering input....I m using ceramic balls and I do sand the diff plate before assembling....can somebody explain step by step on the right way to set up a diff? And how smooth the diff should be?
Thanks...
Thanks...
#7888
thnz for da info. rely owe u alot...
#7889
Thanks...
Thanks...
#7890
Thanks...
Thanks...
A while back I wrote up a build diff procedure but it was for my cyclone. I will see if I can find it.
