Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 01-12-2010, 07:12 AM
  #7801
tandman's Avatar
Stilo, please pm me the setup or post here.....I have both cars, WE and X
Thanks, Dwayne Flodell
tandman is offline
Old 01-12-2010, 08:27 AM
  #7802
Stilo's Avatar
Final setup from DHI
Itīs kinda basic stuff for Sorex/LRP tires.
Things that I would have wanted to test at the event were:
-no shims in wheelhexes
-6mm under front ballstud
-C-C XA-Blocks
But too much to change and so few heats...
That setup doesnīt turn much, but it keeps the speed through corners better.
Some driver were traction rolling, but it wasnīt a problem for most of the drivers.
Stilo is offline
Old 01-12-2010, 09:12 PM
  #7803
dsrbltoys's Avatar
Originally Posted by Toh WL
Just check with you all on the arms. Do Tamiya produces aluminium short reversible arm for 416WE/X? If not what about 3rd party manufacturer.
Does aluminium arms good enough to bullletproof my car. What in case of major crash. I do believe the suspension mount will bend rite?
No alloy arms for sedans from tamiya. The only 1/10 car they ever released alloy arms was on the TB01. Well actually they were released for TG10 gas car which used same suspention as TB01, then they released the first long arm conversions.
I ran them on both gas and elec at that time. I would look else where to bulet proof it. Alloy will bend tweek or break too.
The current carbon arms are damn strong, and and the short set is even stronger.
Kevin
"Tamiya Durability Tester"
dsrbltoys is offline
Old 01-12-2010, 09:25 PM
  #7804
tandman's Avatar
Stilo, thanks......
What is the exact effect of cutting the top-deck? What would the car be doing to want to cut it? Also, your droop measurement...how are you measuring it?
tandman is offline
Old 01-12-2010, 11:23 PM
  #7805
Toh WL's Avatar
Kevin
Yes true but the carbon arms do break that's all I experienced.
Toh WL is offline
Old 01-13-2010, 03:13 AM
  #7806
s13evo's Avatar
your thoughts on 3Racing Bottom Deck Chassis for the TRF416? has anyone used one before. is it just as good as the OEM one.
s13evo is offline
  #7807
Trader Rating: 51 (100%+)
Speaking of breaking arms, does anyone know if a company makes a hard bumper for the 416X? I think Parma does, but I don't think it they have one specifically for the 416X.
Can't wait, picking up my 416X today or tomorrow!!
Apex is offline
Old 01-13-2010, 04:57 AM
  #7808
dodo's Avatar
i think they will eventually do, perhaps if you really hit it hard or hit the weakpoint. but it does not regulary break if you hit the barrier or worn.
i use 415 for 1yr + to race mod and experienced front knuckle break or susp mount bent, but no arm breakage.
similar with TA05 for 4 years
dodo is offline
Old 01-13-2010, 05:15 AM
  #7809
Toh WL's Avatar
Talking about bumper I do not see any issues with the original one.
But there is a problem with bumper holder TAM51253. What happen was the 3 screws to the chassis came out upon impact or loosen. Although I changed it to new one & use longer screw. It does not solve the problem. This is the design weakness. That's why I always check & tighten when neccessary.
If anyone has good idea overcome this. Appreciate the assistance....
Toh WL is offline
Old 01-13-2010, 05:26 AM
  #7810
Toh WL's Avatar
It happened when I ram the right side of the wheel. The arm did break, the steering linkage bend & the knuckle came out. I lose the flanged tube, shims & the screws..
If Tamiya would have rubber bumper in replacement to original foam bumper. Most likely my car would be safe. Not forgetting the hardened material for TAM51253 in support of the bumper.
Toh WL is offline
Old 01-13-2010, 05:27 AM
  #7811
Senna Racing's Avatar
I had this problem
Used a bit of zap
Allow to half cure then set screws
can take off when need but is rock solid
were before I would tighten ever 2 races
Senna Racing is offline
Old 01-13-2010, 05:45 AM
  #7812
Toh WL's Avatar
Originally Posted by Senna Racing
I had this problem
Used a bit of zap
Good suggestion.. thanks.
Toh WL is offline
Old 01-13-2010, 06:06 AM
  #7813
Hy!
What will be a good FDR for an lrp 13*4 brushed motor on a 416we?
Thanks!
Davzone is offline
Old 01-13-2010, 07:20 AM
  #7814
jonest's Avatar
Toh,
U seems like an experienced "416 breaker"
Well, I've raced the 416 for more than a year and arms are still solid!!!
Yes, I do agree that sometimes that screw could come loose so do check them occasionally.
jonest is offline
Old 01-13-2010, 07:23 AM
  #7815
dameetz's Avatar
I sold my WE and got me 416X today....I m really excited about it and hopefully I can put it together in the next weeks. Any advice before I start? Will the same set up from my WE works with the X? I m usually using Jilles basic outdoor set up for my local unprepared outdoor track...
dameetz is offline
