Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 12-02-2009, 07:57 PM
  #7321
tandman's Avatar
Muchhobby in Canada says they have the 416x in stock
tandman is offline
Old 12-02-2009, 10:28 PM
  #7322
Mine will be here tomorrow
JoeGlover is offline
Old 12-03-2009, 04:49 AM
  #7323
dameetz's Avatar
How much is this 416X cost? My LHS is quoting me a ridiculous price...
dameetz is offline
Old 12-03-2009, 05:07 AM
  #7324
Some one gave a website a day or two ago for USD489. That seems fair.
I don't think it will be cheaper when HK shops start selling it ( rcchamp in Japan is also around 500 usd )
gimpex is offline
Old 12-03-2009, 09:55 AM
  #7325
Hebiki's Avatar
Trader Rating: 26 (100%+)
dameetz: are you in the US? speedtechrc has them coming in.
yup... speedtechrc.com priced it pretty competitively. if you're in the united states you'd probably save on shipping, etc. last i talked to him he still had a few left from his preorder/first batch shipment.
Hebiki is offline
Old 12-03-2009, 10:18 AM
  #7326
TimPotter's Avatar
Trader Rating: 14 (100%+)
Got mine Pre-Ordered through SpeedTech
TimPotter is offline
Old 12-03-2009, 10:39 AM
  #7327
think your selves lucky your in the US
us in Europe have to pay €550
that is $830
shite , shite , shite
that is why i am staying with my 416we for another year
sidecarphil1 is offline
Old 12-03-2009, 10:42 AM
  #7328
Hebiki's Avatar
that is $830
wth?!?! why not just order from here.....and get it shipped there? still save you at least $200USD.
Hebiki is offline
Old 12-03-2009, 10:43 AM
  #7329
syndr0me's Avatar
Trader Rating: 32 (100%+)
that is $830
Or order from RC Champ, you can get the cars for a pretty good deal depending on the current exchange rate.
syndr0me is offline
  #7330
then the customs hit me and i save $50
i will wait till it is available from Hong Kong and see if i can get one
Old 12-03-2009, 10:49 AM
  #7331
Stein Tumert's Avatar
that is $830
430 Euro here in Switzerland (if you order before 06.12)
http://www.rccarshop.ch/index.php?page=index
Stein Tumert is offline
Old 12-03-2009, 10:51 AM
  #7332
Euro 340 ( USD 515) from RCChamp in Japan...but I am not sure if they also under-declare the value like the HK shops
I think HK should have them within the next two weeks
gimpex is offline
Old 12-03-2009, 11:10 AM
  #7333
jonest's Avatar
Originally Posted by Toh WL View Post
Jonest,
To what I did a physical check the between the 416 & the 416WE. The notable difference is the battery holes are much to the front for 416WE. Hence much of the battery weight are shifted towards the front wheels. Hence the 416 lower deck is not the same as 416WE.
When you say the battery position is the same as the original 416's. Do you mean the 416X chassis is compatible with the old 416?
I was thinking also anyone did modification for the ori 416 to 416X.
Thanks....
Toh,
All chassis are different from each other.
1) 416 vs 416WE battery position moved forward 5mm
2) 416 & WE vs 416X rear diff moved backward by 1.8mm & motor mount moved in centreline (belting) by 1.0mm
3) 416 & 416X battery position same, hence different compared with WE.
I have both the 416 & WE but I'd still prefer the original 416 (more steering), but I'd upgrade the top deck & motor to WE.
The only thing u could use from 416X on 416 & WE is the motor mount but u need to remove some carbon on the lower deck, where the motor sits. But if you like to up grade ur 416 to 416X, u will need the new top deck, lower deck, motor mount & rear bulkhead, maybe the front bulkhead as well (this I'm not too sure).
Hope this helps.
jonest is offline
Old 12-03-2009, 12:40 PM
  #7334
entitymugenmtx's Avatar
Trader Rating: 85 (100%+)
Originally Posted by entitymugenmtx View Post
Where do you add the .2mm shims so you can take care of the leak. The only thing that I shimmed was the shock shaft I put 0.1 shim under the piston and one on top of it.
Can you help
entitymugenmtx is offline
Old 12-03-2009, 01:59 PM
  #7335
TryHard's Avatar
Originally Posted by Blueman Austria View Post
You add the shim (i think) between the two delrin bushings in the Damper cylinder so that the O-ring is more squeezed.
I have already ordered them. You need the 4mm ones 53586 i think.
Greetz Blueman
Originally Posted by TryHard View Post
Unless you build them as the WE method, where the O-ring is between the spacers... so then it goes against the shock body and upper spacer
HiH
Ed
TryHard is offline
