Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 11-14-2009, 09:16 AM
  #7066
HY Everyone,
I need the circled thing's item number.
[IMG]http ://images.netbag.hu/20091114/18083031494.jpg[/IMG]
(I'm not allowed to post links because i don't have enough post.Just delete the unneeded SPACE character after the http)
If i'm right that is a cooling thing for the motor,fresh air cames from under the car chassis and it is cooling the motor,so if someone knows the item number please tell me!
Davzone is offline
Old 11-14-2009, 09:19 AM
  #7067
entitymugenmtx's Avatar
Trader Rating: 85 (100%+)
http://images.netbag.hu/20091114/18083031494.jpg
entitymugenmtx is offline
Old 11-14-2009, 09:36 AM
  #7068
Originally Posted by Davzone
HY Everyone,
http://www.speedtechrc.com/store/ebp...id=614&id=8706
Old 11-14-2009, 10:01 AM
  #7069
Thanks, That's it.
I was searching it for days but i didn't find a page where can i chechk all the parts and hop ups for the 416.
What do you think about this Air Duct?
Worth it?
Will my motor run cooler actually?
Davzone is offline
Old 11-14-2009, 10:15 AM
  #7070
swimbikerun's Avatar
Trader Rating: 108 (99%+)
Thanks, That's it.
Worth it?
Not sure if the motor runs cooler but it does provide a solid space to secure your speedo to and it's blue.
swimbikerun is offline
Old 11-14-2009, 01:31 PM
  #7071
yokemad's Avatar
adding more shims to steering pushes the steering rods to forward = more parallel links=more twitchy car
that's right isn't it?
I don't like ultra responsive twitchy car, my xray is so easy to drive and very forgiving with 3th ankerman position which is angled...
5.5mm shims sounds a bit too much to me how many mm you guys recommend ??
thanx for all answers&advices
yokemad is offline
Old 11-14-2009, 02:19 PM
  #7072
for indoors i run 4mm because it settles the steering a little
outdoors i run 5mm or 5.5mm bepending of grip and amount of steering i have/need
sidecarphil1 is offline
Old 11-14-2009, 03:25 PM
  #7073
yokemad's Avatar
cheers Mate
yokemad is offline
Old 11-14-2009, 03:36 PM
  #7074
when the 416X available?
silverM3 is offline
Old 11-14-2009, 04:22 PM
  #7075
SammyZ's Avatar
Trader Rating: 138 (100%+)
Originally Posted by sidecarphil1
i used 44's all summer long outside with no problems
then i went indoors and at tthe first race meeting i broke 3 spool outdrives before i realised i needed 46's
i will always use 46's now but i feel that sometimes on full lock they tend to tie the car up , i am now using 1C 1C front not 1D 1D i was using so maybe i will be ok with 44's
hey, how did you break the spool cup using 44mm CVD?
I broke one last week with the 44mm bone indoors
after a hard hit.
SammyZ is offline
Old 11-14-2009, 08:18 PM
  #7076
JasonC's Avatar
Trader Rating: 120 (100%+)
i dont get the problems everyone seems to be having with the spool drive cups and using the stock drive shafts. i have 40+ runs ith 13.5 and mine still ins good shape.
JasonC is offline
Old 11-14-2009, 11:20 PM
  #7077
after a hard hit.
i got hit on the right side going into the first corner
then the others were just not in the spool out drive far enough
Old 11-15-2009, 12:03 AM
  #7078
syndr0me's Avatar
Trader Rating: 32 (100%+)
What kind of track are you running on? Mine exploded on carpet with boards. I was lucky to get more than a run out of them. Jilles suggested using 46's in his videos, so presumably we're not the only ones that have experienced the issue.
Are there any tracks near Oceanside? I grew up in Carlsbad, used to race at Hot Trick & E&L back in the day.
syndr0me is offline
Old 11-15-2009, 04:30 AM
  #7079
I'm looking at getting a 416X next month since I just sold my Evo 5 MS but I do have a question. Can you flip the drive train/belts left to right and right to left like on the TC5 and XRay to better balance the chassis? I assume you could only if you run a spool up front.
Old 11-15-2009, 04:38 AM
  #7080
Trader Rating: 38 (100%+)
Originally Posted by swimbikerun
I'm looking at getting a 416X next month since I just sold my Evo 5 MS but I do have a quesion. Can you flip the drive train/belts left to right and right to left like on the TC5 and XRay to better balance the chassis? I assume you could only if you run a spool up front.
Aside from the belt tensioner on the upper deck it appears everything would work. As long as the battery didn't interfere with the long belt.
or8ital is offline
