Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 09-08-2009, 04:43 PM
  #6481
mattyau's Avatar
when i apply loctite i hold the grub screw with my 1.5 Hex Driver then i have it just pointed up tilted forward a little then just sqeeze the bottle to u see the loctite starting to get near the top of the cap. then i sort of hold the bottle in 1 hand and my 1.5 with the grub in the other then u sorta point the tip of the bottle towards the screw and rotate your 1.5 and spin a fine ammount other the threads of the grub screw. Lol. i guess that sounds confusing ( it also helps to cut the tip of the bottle on a slight angle \
mattyau is offline
Old 09-08-2009, 05:20 PM
  #6482
veecee's Avatar
Trader Rating: 34 (100%+)
Originally Posted by rnd_tang
Just started building the spur gear section of my 416 last night, having a hell of a time finding the 0.2mm shim (BR2). Is this a silver or blue part? I m pulling my hair out.
I went and got myself some Loctite CA as well, the liquid type. I found this method much easier. All I did was drop it on the edge and let gravity pull it along. Do I have to go around all the internal edges as well?
Thanks.
It would be a silver part, in its own little bag with a blue paper label marked 0.2mm.
I normally CA the outside edges only. It is mainly to prevent the CF delaminating in a bad crash. It would be pretty rare for that to happen on the inside edges.
veecee is offline
Old 09-08-2009, 06:50 PM
  #6483
mickrcarver's Avatar
Trader Rating: 101 (100%+)
anyone want to sell a 416we?? paypal waiting
mickrcarver is offline
Old 09-08-2009, 06:52 PM
  #6484
kschu's Avatar
Trader Rating: 16 (100%+)
DCJ for TRF416
www.kkeprc.com
kschu is offline
Old 09-08-2009, 07:01 PM
  #6485
veecee's Avatar
Originally Posted by kschu
DCJ for TRF416
www.kkeprc.com
Are they made by Atomic? I'd like to see an image of them in the car as I'm not sure how those things fit with the standard C-hubs. I know the Xray needs option C-hubs.
veecee is offline
Old 09-08-2009, 07:06 PM
  #6486
Cool thanks! I was looking through the spacers bag for it I think.
Outside it is. Cheers.
rnd_tang is offline
Old 09-08-2009, 07:40 PM
  #6487
kschu's Avatar
i think so...but i see d 416 c-hub hole shud be enough big for the dcj...
kschu is offline
Old 09-09-2009, 04:37 AM
  #6488
So... I m trying to fit the upper deck now.
Is there any way to get this thing on without having to shave it?
Edit: OK I did it. I loosened the screw at the front. The thing holding the front one way. Then I screwed the deck on (after taking a tiny bit off with a file) and then screwed the front back down.
rnd_tang is offline
Old 09-09-2009, 04:56 AM
  #6489
try it first
mine didn't fit though and i needed to shave a bit off the front and the rear
fits loverly now and it doesnt matter that it is shaved
sidecarphil1 is offline
Old 09-09-2009, 05:00 AM
  #6490
DCJ for TRF416
www.kkeprc.com
where do i get these from ???
Old 09-09-2009, 04:22 PM
  #6491
How important is the Anti Wear Grease on the inside of part BC3? Do you guys use it? Any alternatives?
rnd_tang is offline
Old 09-09-2009, 05:28 PM
  #6492
over gear's Avatar
Trader Rating: 18 (100%+)
http://store.hkshobby.com/product_in...c54331fbef62ab
over gear is offline
Old 09-09-2009, 05:37 PM
  #6493
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Does the manufacturer of those driveshafts have a website?
Randy Caster is offline
Old 09-09-2009, 05:44 PM
  #6494
veecee's Avatar
Randy I'm almost certain Atomic makes them - ie the guys that make the VM2 4wd mini. But it's not on their website.
veecee is offline
Old 09-09-2009, 05:54 PM
  #6495
veecee's Avatar
According to this website, manufacturer is Spec-R - http://www.egrracing.com/shop/specr-m-62.html. I think they must be closely connected to Atomic in some way since they are making these unis for their mini (but only 2 other cars) and is sold/distributed by companies that also sell a lot of Atomic products.
veecee is offline
