Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 12-17-2007, 03:40 PM
  #616
syndr0me's Avatar
Trader Rating: 32 (100%+)
Platinum size LiPo are going to be no problem in this car. The motor mount and antenna mount will also work to keep the battery from sliding around, in toward the belt. Awesome.
syndr0me is offline
Old 12-17-2007, 04:56 PM
  #617
Vicko's Avatar
Trader Rating: 14 (100%+)
so are the arm different on the 416 then the 415?
Vicko is offline
Old 12-17-2007, 05:05 PM
  #618
Default set-up
hey guys,
the setup i posted was using all the stocck stuff including the swaybar. However for the next outing I will be trying more things so I may not end up with all stock pieces. Things i plan on changing are susp. blocks(looks like older ones will fit), short arms, springs and probably swaybars. Dont worry tho, the car handles great the way it is now so dont feel obligated to buy more parts....atleast not yet!
As for for quality of some parts, you guys just may be the pickiest people i have ever seen LOL! Just enjoy the CAR itself!!
TRFwhitey is offline
Old 12-17-2007, 05:09 PM
  #619
TryHard's Avatar
Nope, same as 415 (standard LWT version).
Front C-hub, Steering knuckle and rear Hub carriers are all different however. (1050 bearings, slightly wider spacing, and slight geometry changes)
regards
Ed
TryHard is offline
Old 12-17-2007, 05:14 PM
  #620
TryHard's Avatar
Originally Posted by TRFwhitey
hey guys,
I was going to go with this as well.... I'll try the car stock to start off, then move the setup closer towards what I currently run on the 415 (certainly in terms of arms, blocks and shocks). So that'll be short arms, 0.5mm under the blocks, and 1.5deg of rear toe in (A/D) with White/Blue springs, no sway bars
I'll leave the rest as is... although I'll measure the car up in a similar manner so I can make up a RC calculator, same as the 415 one I did.
Regards
Ed
TryHard is offline
Old 12-17-2007, 05:42 PM
  #621
veecee's Avatar
Trader Rating: 34 (100%+)
Got my car this morning as well. Hope to start the build tonight. Everything looks sweet!
veecee is offline
Old 12-17-2007, 05:47 PM
  #622
Anthony.L's Avatar
Trader Rating: 41 (100%+)
Come on Corey, you know Tamiya people, the majority build a car to look at not race.
Anthony.L is offline
Old 12-17-2007, 06:14 PM
  #623
Racing4Evo's Avatar
Can I just use the diff pulley and my existing parts to make a 12 ball diff for my MSXX? I don't think I will be getting a new car.
Racing4Evo is offline
Old 12-17-2007, 06:29 PM
  #624
RC MARKET's Avatar
Same 51104
RC MARKET is offline
Old 12-17-2007, 07:34 PM
  #625
Default re
haha, ya ur right.
One thing people should be happy about is the fact that the old c-hubs fit as well. So until all the parts are available almost all breakable parts(susp. pieces) are interchangeable with the 415 so you can atleast race for the day.
I tried a setup i ran on my 415 but did not like the feel, the main difference being i did not run swaybars on the older car. Corner speed improved dramitcally when i installed them on the 416. However this may be due to the fact i did not have thick enough oil in my shocks.. think of it like lotus's approach , soft springs and stiff swaybars. The real test is when i put my lrp 4.0 back in tho! 19T=tooooooo slow lol
Old 12-17-2007, 08:32 PM
  #626
miccal's Avatar
Trader Rating: 23 (100%+)
Mine arrived, I am in Australia. Can't wait to start building.
miccal is offline
Old 12-17-2007, 11:35 PM
  #627
syndr0me's Avatar
What's the internal ratio of this car?
syndr0me is offline
Old 12-17-2007, 11:42 PM
  #628
JimmyMac's Avatar
You mean to tell me... you are building this car right now and you don't even know???? Page 20... 37/18=2.055
JimmyMac is offline
Old 12-17-2007, 11:56 PM
  #629
syndr0me's Avatar
Ug, I found it. I'm in a daze, it's been a long day.
I'm not sure it's going to be easy to properly gear a 13.5 with the 13mm sintered rotor (or a LRP 13.5/sintered). It looks like anything larger than a 47T pinion will hit the top deck. I may have to find some much smaller spur gears.
syndr0me is offline
Old 12-18-2007, 12:12 AM
  #630
Swift and Sleek's Avatar
Smile 416
Originally Posted by buboy28
Hmmmmmmmmmmmmmm, looks like i have to wait for the MS or MRE version
I think me too...
Maybe "TRF 416MS" OR "TRF 416 MRE"
I don't know but I might be wrong its still looks like a 415... with little tweaks...
Maybe some guys here are already thinking of what the MS OR MRE kit might look like.
Attached Thumbnails Tamiya TRF416 / TRF416WE / TRF416X-416-415.jpg   Tamiya TRF416 / TRF416WE / TRF416X-trf-415-416.jpg
Swift and Sleek is offline
