Tamiya TRF416 / TRF416WE / TRF416X
#6152
Congratulations to Jilles with the European Championship.
5 of the 6 first --> Tamiya 416
#6154
I have a question for you guys on Lipo weight trays. Where are you guys buying them from for your 416's? I've heard there's some that cost as much as $50 and others you have to modify to fit, but more importantly, they help the car handle better than running a strip of lead weights.
I am running a 416WE with a 2.5mm chassis and using SMC and Thunder Power 40C packs. With this combo, there appears to be slightly less than 1mm of space between the top of the battery and bottom of the top plate. Which is the best one for our car?
Thanks, Chris
Thanks, Chris
#6155
hey chris, i had that same issue where my smc 5200/40c pack had a 1mm gap between the top deck so i had to mount the battery almost half way off the chassis, i said f-it and sold that pack and i just bought that 4700/40c smc pack. if you hold the car up and manually flex it with the 5200 in it you will notice how it hits the top plate, as far as the tray thing check out ppd or pdp or something its around here somewhere
#6157
Thanks, Chris
Thanks, Chris
I am using the XRAY Lipo Balancing Weights.
http://www.teamxray.com/teamxray/pro...ssis%20Weights
#6158
#6159
Ok I am going to get the 416 I have always wanted to get this car but I just keep putting it off trying to make the car I have work but it is not what I am looking for, I drove my buddy car and it is what I am looking for, now the question is what is the difference between the 416 and the 416WE? if it is only small changes that was made on the 416WE I would go with the req 416 because it cost less and if the changes that were made on the 416WE made the car handle much better then I may get the WE.
#6160
those xray things are pretty nice and honestly that 009 looks really nice too, but i like my 416we much much better. i bought mine like 6 months ago and had it sitting around since until i ran it a week ago and i was instantly hooked! so far it is the best tourer i've ever had, i sleep with it at night so i dont have bad dreams
hey what do you guys think about those new split arm mounts?
#6161
#6162
You would need
shorter arms
shorter dog bones
top deck
chassis ???
#6163
Probably much stronger & less likely to bend. Of course the only blocks I've ever seen bend are the ones towards the rear of the car on both the front & rear suspension. Probably not worth the extra cost for the front of the rear suspension.
TC crashes typically are in the forward direction. This is why the rearward blocks get damaged. Because the suspension is being pushed back the wall. The arm, hinge-pin & rearward block absorb the impact...
#6164
#6165
The split mounts are great . its easier to change a broken arm and makes changing belts that much easier. also have a double setting so you have 2 for the price of one.
