Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 06-29-2009, 10:41 AM
  #5791
Originally Posted by syndr0me
It seems to me that maybe my car didn't have that problem when it was new, but developed it over time. My bulkheads all appear to be straight when I lay them on a flat surface, so maybe it's something with the chassis developing a curve over time? It always seems to tweak out fine once I tighten down the top deck with the car compressed at the shock towers. It's a shame nobody makes those chassis flattening plates for this car.
Check your hardware.. You might have a bent screw.
John St.Amant is offline
Old 06-29-2009, 10:59 AM
  #5792
swimbikerun's Avatar
Trader Rating: 108 (99%+)
Does anyone know if the stock TC5 or Parma bumper fit the 416/Evo5 without too many mods? Just looking for a little more protection than the Tamiya ones. Thanks.
swimbikerun is offline
Old 06-29-2009, 01:36 PM
  #5793
StickyFingaz's Avatar
Trader Rating: 17 (90%+)
I run a P-Dub bumper for a TC5... i just needed to drill a cuople different holes. Now I can barge my way to the front....
StickyFingaz is offline
Old 06-29-2009, 02:02 PM
  #5794
Johnny Wishbone's Avatar
Yes it will work.
Johnny Wishbone is offline
Old 06-29-2009, 02:46 PM
  #5795
i was wondering on my car why the front left corner had more play in the inner pivot for the lower arm
looked at the suspension bridge but it was ok
looked at the titanium screw and it was bent .....
oops
sidecarphil1 is offline
Old 06-29-2009, 02:47 PM
  #5796
oops
Old 06-29-2009, 03:09 PM
  #5797
those tamiya titanium screws are :-
A, heavy 10g more than the standard ones !!!
B, made of chocolate !!!!
just ordered the TB evo MS screw set , to try see if it is lighter with the alloy upper screws
Old 06-29-2009, 03:16 PM
  #5798
My 415 was an ounce lighter with the Titanium/Aluminum screw kit.
Come to think of it .. so was my 416
Old 06-29-2009, 04:09 PM
  #5799
CraigM's Avatar
Trader Rating: 34 (100%+)
The ti screws are 25g lighter than steel, but you shouldn't use them on the front-rear block. Even with steel these will still bend, and if they don't the block will. Use longer screws if you aren't already, and stay off the boards
CraigM is offline
Old 06-30-2009, 12:03 AM
  #5800
jonest's Avatar
Guys,
I used to have spool cup breakages hence I changed to 46mm swing shaft on the front but I find it'll slow down my car.
Is this true?
jonest is offline
Old 06-30-2009, 12:39 AM
  #5801
CraigM's Avatar
Originally Posted by jonest
Guys,
Is this true?
It increases chatter, which will cause you to lose a little steering. I think I only ever broke 2 spool cups when using the 44mm vs none when I used the 46mm
CraigM is offline
Old 06-30-2009, 01:09 AM
  #5802
jonest's Avatar
I broke NONE with the 46mm but the suspension travel seems funny. I'm running 6mm (F) 5mm (R) downstop setting.
jonest is offline
Old 06-30-2009, 01:49 AM
  #5803
i run the 46mm steal shafts after i broke the alloy 44mm ones , but i havn't broken an out drive , wore one out though
my steeringg and suspension have not changed , but i use 5mm 4mm downstops
the titanium screws were heavier , i cant understand it !!!
did bend the steal screw for the front , rear suspension mount , how do i stop it happening ???
Old 06-30-2009, 02:51 AM
  #5804
Stein Tumert's Avatar
...by not hitting things...
Stein Tumert is offline
Old 06-30-2009, 08:14 AM
  #5805
Thats where I'm at too!
