Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 06-21-2009, 01:53 PM
  #5746
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
For some reason, the track looks a lot smaller than it actually is in the vids...
Randy Caster is offline
Old 06-21-2009, 01:58 PM
  #5747
STLNLST's Avatar
Trader Rating: 32 (100%+)
Yes it does.
STLNLST is offline
Old 06-21-2009, 03:34 PM
  #5748
Goingfast's Avatar
Trader Rating: 29 (100%+)
Does Tamiya make one way diff for 416 WE? if so where and what are the parts numbers?
Goingfast is offline
Old 06-21-2009, 03:53 PM
  #5749
3454520 ... thats the one way housing.
You will need the pulley off the spool and drive cups...
53451 is the (diff joint) lol... Drive cups
same as the 415msx
John St.Amant is offline
Old 06-21-2009, 04:41 PM
  #5750
Goingfast's Avatar
same as the 415msx
John Thanks
I won the club race...I but I was having problem in the mid turn and it like almost dead stop on off power...
i tried to loosing up the rear ,so to get the car can flow around the corner faster ....
I copy Jilles set up ( ETS)
except instead I';m using rear block 1XA/1C ( less toe in)
I took out the shim spacer @ rear upper arm to zero shim for quicker react ( roll center)
I lay the rear shock ,one hole more to inner..
Old 06-21-2009, 10:22 PM
  #5751
John Thanks
How'd all that work for you . Mid corner I probably would have gone for an ackerman change. A wee bit more .
Old 06-21-2009, 11:23 PM
  #5752
TryHard's Avatar
Originally Posted by B18C Turbo
so the TRF415 belts fit? i really liek the white, i had some team bomber white belts in my yokomo and they looked slick. I just wanted to check with you guys to see if TRF415 belts fit the TRF416?
They don't fit, end of.
Pulleys are bigger 37/18, and the layshaft is further back in the car vs the 415, so the front is longer, and the rear shorter.
TryHard is offline
Old 06-22-2009, 09:24 AM
  #5753
CL
CL's Avatar
Trader Rating: 34 (100%+)
Default Blue aluminum turnbuckle?
I notice that this car comes with blue aluminum turnbuckles. when you're building the car, do U guys use them or do U guys just toss them and replace them with the titanium ones ?
CL is offline
Old 06-22-2009, 09:25 AM
  #5754
Hebiki's Avatar
Trader Rating: 26 (100%+)
the long ones that are used for the steering... i didnt even bother using those. i grabbed the steel/alum. reinforced ones that tamiya has for their 501x buggy.
Hebiki is offline
Old 06-22-2009, 09:37 AM
  #5755
94eg!'s Avatar
Trader Rating: 17 (100%+)
Yeah, even the camber links can get banged around and bend a little, but those are much less trouble than the steering tie rods. TRF now sells really nice blue titanium ones, but they are $14-16 a pair form some of the better sellers.
rdvtg-hobbies on eBay is one of the best for these. Cheap shipping and gets here under a week.
Of course Tamiya had to make the adjuster a different size so you need a special wrench too. And for some reason they forgot to mark these new turnbuckles, so pay close attention to which side has the reverse thread when installing them...
http://stores.shop.ebay.com/Rdvtg-Ho...=blue+titanium
94eg! is offline
Old 06-22-2009, 09:42 AM
  #5756
CL
CL's Avatar
Wow! That was quick. So those blue alum turnbuckles are strong enough for F/R camber link? Have U broke them yet?
CL is offline
Old 06-22-2009, 09:52 AM
  #5757
CL
CL's Avatar
$16 a pair. Ouch! I'll try to find some silver ones of the same length from Lunsford.
Thanks.
CL is offline
Old 06-22-2009, 10:04 AM
  #5758
syndr0me's Avatar
Thanks.
I did this on day 1, and it's been fine. Even the titanium steering rods will bend on occasion, so grab some extra.
syndr0me is offline
Old 06-22-2009, 10:09 AM
  #5759
Thanks.
Thats not bad .. The hobby shop here tried to rip me off for $28 for the same part.
Old 06-22-2009, 11:34 AM
  #5760
Goingfast's Avatar
Well still lacking in the mid turn...
I got 5mm shim spacer right now for steering ball end...should I added more spacer to what?
How would Ackerman works does Mid turn more??
