Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 06-08-2009, 10:33 PM
  #5641
Originally Posted by CraigM
Hi Phil,
B if i put 0.5 on the front and 0 extra on the rear what will this do ??
-> do you mean make them both 1mm total? This will take away your anti dive (less initial steering, more weight transfer to front under brakes) and also raise the front roll centre (less steering)
i ment 0.5 mm spacer front front and 0.0 front rear
and does D D on the front help ??
->D/D will take away some steering, it also makes the car easier to drive as it's less twitchy.
cool it is a little twitchy
i run C C at the moment and it seams to push the front end on a bit ...
->this would be from the high front RC, the front tends to skate in corners when you have a too high front RC compared to the rear. Try going to 0 under the front-front block and 0.5 under the front-rear, with 5mm of spacers under the front camber link on the bulkhead. You should also have 0.5mm under both rear blocks, and rear camber links flat
got no spacers under the rear blocks
what is the camber link ???
sorry technical terms still confuse me LOL
sidecarphil1 is offline
Old 06-08-2009, 10:52 PM
  #5642
CraigM's Avatar
Trader Rating: 34 (100%+)
that will give you 1/2 a degree of front kick up, also known as prodive. Basically the opposite to anti dive, the car will transfer more weight forward under brakes. It will also soak up bumps better. I've never felt the need to use it with my 416, even on bumpy tracks
D/D on the front will sort that out, make sure you have the 1mm wheel spacers in the front
That is definitely the cause of your understeer problem. 0.5mm under both rear blocks (xa/d is what I run there), 3mm under the camber link on the hub side, and 4mm on the bulkhead side (aka the base asphalt setup)
The camber links are the turnbuckles front and rear that you adjust the camber of the wheels with. The amount of spacers under the ball screws they connect to determines the roll centre
CraigM is offline
Old 06-09-2009, 05:07 AM
  #5643
penmark67's Avatar
Trader Rating: 14 (100%+)
Default Ok
So are you saying that a C/C front combo offers more grip than 1C/1C ?
And the 4mm under the rear inner link will give less grip than 3mm ?
Mark M
penmark67 is offline
Old 06-09-2009, 05:55 AM
  #5644
sonic31's Avatar
Trader Rating: 6 (88%+)
can anyone tell me what spur gear they run for a 13.5 on the 416? im using a speedpassion 13.5. thanks for any help.
sonic31 is offline
Old 06-09-2009, 06:43 AM
  #5645
Mark M
sorry mark it's me being lazy not typing the 1 in
i use 1C 1C and will go to 1D 1D on the front
i have on the front camber spacer the base asphalt set up and rear is 4mm inner and 3 outer i think
base asphalt set up with softer springs and no rear roll bar and 40 oil in the shocks , slightly longer wheel base and 1XA 1D rear ,
car feels good but not as planted as my mates Xray 009 and i want it too and know it can ... i need this half second a lap
Old 06-09-2009, 07:54 AM
  #5646
What speedo you running? I run the SPX and I run between 100 to 102 to get the gearing I need for my 13.5
COREY LEWIS is offline
Old 06-09-2009, 08:06 AM
  #5647
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Hey Corey, you been out to the track with the new car yet?
Randy Caster is offline
Old 06-09-2009, 08:59 AM
  #5648
Whats up Randy, I have only been to the tamiya track. I want to get down to OCRC this week. When are you going to be down there?
Old 06-09-2009, 09:05 AM
  #5649
Hebiki's Avatar
Trader Rating: 26 (100%+)
there goes the neighborhood! see you guys on saturday.
Hebiki is offline
Old 06-09-2009, 09:10 AM
  #5650
Korey Harbke's Avatar
Corey Lewis LIVES!!!!
Korey Harbke is offline
Old 06-09-2009, 09:34 AM
  #5651
I'm gonna go down there tomorrow. Numan is gonna stop by and run too... They open at 3 and then go until offroad racing is over (10-11)
Old 06-09-2009, 10:01 AM
  #5652
The SPX on profile 7 need far less gear that he would use on the Speed Passion.
Thing is , track size and type determine gear more than speed controls.
Its best to take a conservative guess and check motor temps after 2 mins.
The car comes with a 105 tooth and thats not bad either.
4.8 or 5.0 would be a good start for a 100 foot straight. Divide that by the internal and the spur gear and that will get you in the ball park.
So whats that like a 105/45=4.79. But thats no good for a tight sticky track. you would less gear for it but the 105 should put you in the hunt for that speed control. The SPX ramps up the timing and I would have something like a 108/34=6.53 for a big track.
Only you can prevent forest fires.
John St.Amant is offline
Old 06-09-2009, 10:06 AM
  #5653
Trader Rating: 27 (100%+)
whois Corey Lewis?
MDawson is offline
Old 06-09-2009, 10:13 AM
  #5654
Hebiki's Avatar
yah Corey.. you have the wrong spur gear! he apparently doesn't know your racing background.
Hebiki is offline
Old 06-09-2009, 10:20 AM
  #5655
Don't be a DICK!
Apparently sarcasm doesn't convert well in typing.
I am only trying to help what ever person to the best of my ability.
And not knowing which moron is playing games here to waste my time is not what these forums are about. Think about that one for a while okay ?!
