Tamiya TRF416 / TRF416WE / TRF416X
#5401
Not only is the pin end/ball larger, but the pins are longer. So not only would you have to dremel out the drive cups, but you would have to cut down the XRay pins to fit within the aluminum sleeves on the outdrives. And you have to be precise on dremeling out the outdrives/cups. You don't want it slightly off center. Another issue you will be faced with is the LCD joint size. The XRay caster blocks has a huge opening to allow the LCD to float in the caster block. The Tamiya caster blocks have tiny openings. So the LCD may not even work with Tamiya caster blocks. Sooo, if you were to dremel down the outdrive/cups, and cut down the XRay pins, you would have to run XRay front suspension as well.
#5403
#5404
#5407
Originally Posted by B18C Turbo
is the rear ball diff in this car supposed to be crunchy even when its fresh?
#5409
It looks like it's still a 2mm pin, so basically it would be easy to just push the pin out, spin the driveshaft in a dremel or anything that it would work in, and sand the ball down while the shaft is spinning. Then just push in a Tamiya 2x10mm pin and it would be fine. Might have to bring the dremel back out for the caster blocks though.
My 009 showing the LCD and large hole caster block. Don't mind the tires...
XRay vs. Tamiya 416 caster block. Can't switch caster blocks either because XRay uses larger suspension pin for the caster block.
XRay ball end (6.8mm) vs. Tamiya ball end (5.8mm)
XRay LCD installed on 416 caster block and steering hub. Notice there is no room for the LCD to function.
#5411
I wish Novak would make the Ballistic series in a 10.5 or even 13.5.
I love the stepped can sensor location.
#5412
#5413
Mac, thank you for the pictures.
I have a question regarding the one above though. It looks like the screw hole at the bottom of the xray C-hub is much larger than the one on the 416 hub. Can you please let me know what diameter it is? And is the one at the top (for the camber link ball) the same diameter?
