Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 03-18-2009, 02:33 PM
  #4846
CHRIS CHAVEZ's Avatar
Originally Posted by CraigM
Myan_gsr our tracks sound very similar, ours is a converted tennis court and we race at night under lights as well as weekends. Victor Wilck's reedy race setup from last year is a great starting point, just incline the front shocks one hole on the tower and raise the rear RC a fraction
Redbones/jimmy I haven't tried the hara springs but I know someone who runs them on his 416 with good results. I'm not sure if it means anything but all the tamiya pros run the hpi's and hara was using them too at the worlds.
I wouldn't worry about getting a full set of the hpi's tho, I've just got a set (4) of silver and blue and they've served me well at every track I've raced on... asphalt only
P.s more ackerman spacers as suggested above will hurt on power steering not help it
which shock weight are you guys using with these hpi/Hara springs?
CHRIS CHAVEZ is offline
Old 03-18-2009, 10:15 PM
  #4847
CraigM's Avatar
Trader Rating: 34 (100%+)
I use 400 normally
CraigM is offline
Old 03-18-2009, 11:52 PM
  #4848
sagejyoung's Avatar
hey guys, i would like to know what the part number is for the oneway (the whole unit), i cant seem to find it on the parts list.
sagejyoung is offline
Old 03-19-2009, 12:15 AM
  #4849
Skitee's Avatar
Front or Center ?
Anyway...
49492 - TRF416 Center One-Way Set
3454520 - One-Way Housing
9444623 - One-Way Joint
54023 - 37T Front One-Way Pulley
Skitee is offline
Old 03-19-2009, 12:19 AM
  #4850
sagejyoung's Avatar
front?
Old 03-19-2009, 12:21 AM
  #4851
sagejyoung's Avatar
apologies.. i would also like to know if the xray spring set will fit the TRF dampers?
Old 03-19-2009, 12:29 AM
  #4852
sagejyoung's Avatar
Thumbs up
also, i would like to know which car the front one way parts come from? i dont wanna have to search each car until i fond the part number that match any help would be greatly appreciated
Old 03-19-2009, 12:43 AM
  #4853
Skitee's Avatar
The front one-way parts come from the original 416(42106).
I read somewhere on here that the x-ray springs do fit the TRF dampers and spring perches.
Skitee is offline
Old 03-19-2009, 12:47 AM
  #4854
sagejyoung's Avatar
ok thanks for all the help do you know if i should be doing anything special to maintain the teflon bearings?
Old 03-19-2009, 01:34 AM
  #4855
wide_mouth_frog's Avatar
Can you use the same sprin retainers with the HPI springs??
wide_mouth_frog is offline
Old 03-19-2009, 01:36 AM
  #4856
JimmyMac's Avatar
The old colored XRay springs fit no problem. The new Black XRay springs still fit, but they are just a hair big. HPI and Hara springs fit no problem.
JimmyMac is offline
Old 03-19-2009, 03:53 AM
  #4857
CraigM's Avatar
The HPI springs are a teeny tiny bit too big for the spring retainer. I've never had an issue in normal use, but in one big off I had a spring jump the retainer. Square was going to bring out some retainers that would be a better fit but I dunno if they were ever released? Dai?
CraigM is offline
Old 03-20-2009, 07:25 AM
  #4858
RC MARKET's Avatar
RIDE
Attached Thumbnails Tamiya TRF416 / TRF416WE / TRF416X-ri-28001.jpg   Tamiya TRF416 / TRF416WE / TRF416X-sun-marcspeedpro-1.jpg
RC MARKET is offline
Old 03-20-2009, 07:51 AM
  #4859
syndr0me's Avatar
Trader Rating: 32 (100%+)
So even though the car tweaks out just fine, and the circles are set the side side-to-side, it still wants to step out very easily when turning right. I've tried a new body, tires, shocks, check hinge pins and bulkheads, etc. Anything else I should be looking at? Can a diff being too lose affect this?
syndr0me is offline
Old 03-20-2009, 07:55 AM
  #4860
Trader Rating: 38 (100%+)
bad bearing on one side? inconsistent droop?
or8ital is offline
