Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 03-16-2009, 12:00 AM
  #4771
Skitee's Avatar
Originally Posted by Ricky/C
If you are gonna run in mod the spool should be fine. A diff might be easier and for stock classess I would get a one way correct me if I'm wrong, but thats what works for me.
Depending on how tight\technical the layout is a one-way will still work, if there are plenty of braking zones for mod then a spool or diff will be best.
Skitee is offline
Old 03-16-2009, 12:16 AM
  #4772
sagejyoung's Avatar
i think i know you bud? hehe ok i've never had to think about braking zones, good point.... and i'll be coming to you for spares seeing all the tamiyas that you own...
sagejyoung is offline
Old 03-16-2009, 12:19 AM
  #4773
sagejyoung's Avatar
Thumbs down
We dont have to run foam?! I'll run rubber! And too bad a TRF beat you at regionals too... Now you're gonna say Skitee is just as good as Marc Rheihard. Well maybe he is
nobody beat me at regionals....
Old 03-16-2009, 12:21 AM
  #4774
Ricky/C's Avatar
He pitted right behind you @ regionals... couldn't have missed Skitee!
Ricky/C is offline
Old 03-16-2009, 12:22 AM
  #4775
Ricky/C's Avatar
I wasn't talking to you. This is crap random...
When will your 416 be here?
Ricky/C is offline
Old 03-16-2009, 12:29 AM
  #4776
Skitee's Avatar
Hehe...I wish I could add a resounding HELL YES I AM but I'm just another average Joe racer
Skitee is offline
Old 03-16-2009, 12:37 AM
  #4777
sagejyoung's Avatar
ok cool, so does anyone have buliding tips? can i use another spur gear, like a standard 48 pitch? i dont wanna have to buy all new tamiya gears for my mod racing
Old 03-16-2009, 12:38 AM
  #4778
Ricky/C's Avatar
OOOOH Who's your man?! I can hit you up. Got loads of spares!!!
Ricky/C is offline
Old 03-16-2009, 12:54 AM
  #4779
Skitee's Avatar
Sage the car will take any gearing format you want to use, so you can use your current stock of gears.
Skitee is offline
Old 03-16-2009, 01:02 AM
  #4780
sagejyoung's Avatar
ok great, i didnt want to have to buy all new gears etc. also do you know what parts can be used from the 415?
Old 03-16-2009, 01:08 AM
  #4781
Skitee's Avatar
If you get the original 416 then the suspension arms are the same but the 416 uses 10x5 bearings in the hubs where the 415 uses 9x5 bearings in the hubs.
If you get the 416 W.E. then you won't be able to carry anything over because it comes with the short lightweight arms.
Skitee is offline
Old 03-16-2009, 01:19 AM
  #4782
Ricky/C's Avatar
What? NOTHING?
Ricky/C is offline
Old 03-16-2009, 01:20 AM
  #4783
sagejyoung's Avatar
its the WE, what about belts, i'll need a few of those.. pullys...
Old 03-16-2009, 01:25 AM
  #4784
Skitee's Avatar
Ricky you could always do the short arm conversion on your 415, I hear it has a pretty good effect on the car...yes I will be doing the conversion on my 415.
Sage if you're going to run mod then yes, you'll need spare belts and pulleys, always make sure your pulleys are in good shape especially the centers otherwise you're just going to tear through belts.
Skitee is offline
Old 03-16-2009, 01:28 AM
  #4785
sagejyoung's Avatar
so if i stock up on some 415 belts and pullys i will be ok?
