Tamiya TRF416 / TRF416WE / TRF416X
#4741
My understanding from talking to people is that you need a stiffer car, like the XRAY US versions or similar...
#4742
i'm looking for a solid trf416, does any one have one for sale chaps? i'll pay shipping etc etc etc
#4743
Sage is sorted... So I'll take that TRF please! Anyone? I've got moooooney
#4744
TRF416WE (#42138) will include the following changes:
New Carbon Lower Deck
New Carbon Upper Deck
High Liubrication (HL) Dampers
New Motor Mount
Short Suspension Arms
New Front and Rear Belts
Front Spool
Teflon Sealed Bearings
Hi guys I found this a few pages back... If I get a 416, how much will all that in the list cost to upgrade it to a 416 WE?
New Motor Mount
Front Spool
#4745
New Motor Mount
Front Spool
New Motor Mount
Front Spool
so need wait moment to upgrade your car !
#4746
So how long? What good is the car if there is no parts support?
#4747
Not every shop on this world has them, but I have nearly all TRF416WE Parts in Stock (http://www.sakaguchinetshop.com/inde..._TRF416WE.html.
I have sold many WE Upgrade kits, they will come 311 euro (note: 459 is the kit price!)
lowerdeck: 76
upperdeck: 22
motorplate: 51
spool: 28
evo5 arms: 14
4x sus mounts: 40
rear 42mm swing shafts: 15
HL dampers: 65
lowerdeck: 76
upperdeck: 22
motorplate: 51
spool: 28
evo5 arms: 14
4x sus mounts: 40
HL dampers: 65
#4748
Thanks a lot! Thats Euro's right?
#4749
The suspension blocks and short arms are a must, but otherwise the only things you should look into are the spool and the 1pc top deck, and these aren't must haves - you only need the spool if you're running 13.5 or lower winds, and the top deck is just a tuning option, you can make the 2pc work in most circumstances
#4750
Plan to run the normal version on asphalt while the WE is kept for carpet racing...
In your opinion, which is better for the different surfaces? And should I change some of the 416 parts to WE version?
Thanks.
#4751
heheheh... u okes wanna buy a 416 for stock( 540 class)
or superstock(27T) hheheh
good luck ...
good luck ...
#4752
I have both the 416 and WE version while I'm kind of disheartened to run the WE on asphalt since it's new..
Thanks.
Thanks.
#4753
#4754
Assuming you're running short arms and wider blocks on the non-WE (no one uses the long arms), the only thing I'd swap would be the top decks as the 2pc would be better for carpet and I like the feel of the 1pc on asphalt. Other than that there's not much in it, WE's base setup is more asphalt focussed but if you want to keep it shiny there's no reason why you cant run the old one... man I wish I had 2
Thanks mate.
#4755
anybody knows the part code/number of the spur gear holder that is included in the center oneway (49492)..
thanks a lot!
thanks a lot!
