Tamiya TRF416 / TRF416WE / TRF416X
#4696
Yeah, bunch of us used those plugs in our TA05's. Works very well. (the tc5 also uses something similar in their new spool but its pads rather then the plugs). Worked out great for the TA05 b/c it comes with two diffs so we didn't need to buy anything more.
I assume those plugs are not TCS legal so save your real spools for that if you plan to do TCS.
Got the EVO V MS on order from Ampdraw. They are waiting for it to arrive though. Hopefully I get it next week. Same suspension so I lurk.
my 416WCE sits shamelessly on my pit table in my garage... stripped of its electronics and dignity.
#4698
Spashett use this !
#4699
I don't own this car, but if I did and had the problem I would definately look into building a slipper spool. Just get a front diff and replace the diff balls with Traxxas slipper plugs. Definately cuts down on the damage as the only part that gives is those plugs on the diff ring.
http://www3.towerhobbies.com/cgi-bin...&I=LXJK92&P=ML
#4701
Slipper clutches acting ont eh spurs are illegal, it has to be direct drive.
Spliff's on the otherhand are fine, as even though they slip, the affect is only on one end of the car... or to put it another way, if you have a loose diff, that'll "slip" too. One-ways are a case in point as well, as off power they are effectively "slipping", i.e. free wheeling.
HiH
Ed
HiH
Ed
#4703
#4704
#4705
What's up Mick
How you been? i swear me and you have the same cars all the time. For the 13.5 motor I run it at 4.5fdr and with a 98 spur I believe it would be a 44 pinion. I ran the 100 spur and 45 pinion when I ran the 13.5 motor. Very easy to drive and great top end for the straights and sweepers.
#4706
HiH
Ed
HiH
Ed
Clever though.
HIGHA , HOW YA DOIN'!?
#4707
( Vicktor Wilck was TQ Today in the Swedish Nats )
#4709
Tamiya took TQ and all the podium in the 3rd round of the ETS series. The youngster Yannic TQ and won the race. Here's the link ETS series
#4710
