Tamiya TRF416 / TRF416WE / TRF416X
#4681
The stock ones are zero deg.
These ones have an aditional 1 deg built into them.
You will need a different Bridge Block if you want to run the same toe in.
Change a total of 2 letters in the front of the rear, for instance... 1B.
#4682
416 aluminum SPOOL CUP
it is under developing.. and Testing.
maybe.. it will be coated by tamiya blue
#4683
Q's : Why would I need the built in toe? Where i can just put different suspension block to get a desire toe in? Is there any different handling characteristic with the built in toe upright?
#4684
Is that made up of metal? I thought metal outdrive will make the chattering worse and will wear the CVD pins faster. Anyhow this will make some of the guys here happy with that news.
#4686
I don't think you'ld notice the difference.
#4687
You mean like progressive toe? Does it increase or decrease the toe during up stroke?
#4688
#4689
#4690
As you change the suspension blocks for more toe-in, the wheelbase decreases ever so slightly from the back since you're angling the arms forward to rotate those wheels inwards.
I've never heard of people changing the uprights for toe adjustment, and most people have spare suspension blocks these days to set any toe they want.. at this point I think it's just a preference to start off with. I'd rather change one little block rather than swap out axles, bearings and wheel hexes between uprights..
#4691
My understanding is that inboard and outboard toe changes affect the car in different ways, and can be used as a tuning option. Here's how Paul Lemieux described it: http://www.rctech.net/forum/4297750-post542.html
#4692
why not just make some delrin ones... sell them 4 to a package..and make a killing that way.
i bet the alum ones will create more chatter too
#4693
I don't own this car, but if I did and had the problem I would definately look into building a slipper spool. Just get a front diff and replace the diff balls with Traxxas slipper plugs. Definately cuts down on the damage as the only part that gives is those plugs on the diff ring.
http://www3.towerhobbies.com/cgi-bin...&I=LXJK92&P=ML
#4694
You sure are lurking in the 416 thread a lot! Is there one if your future, or did you find that EVO 5 MS? My 416 is taking a break while I have fun with the TA05.
#4695
I assume those plugs are not TCS legal so save your real spools for that if you plan to do TCS.
Got the EVO V MS on order from Ampdraw. They are waiting for it to arrive though. Hopefully I get it next week. Same suspension so I lurk.
