Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 03-05-2009, 07:46 AM
  #4651
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Originally Posted by Hebiki View Post
Max, you've seen how hard i drove my 416... how the heck are you guys breaking spool cups? i just inspected mine... still in good shape! then again i only 10.5 on it a few times..and 13.5 most of the time.
- Chris
I'm wondering the same thing. I don't even get much wear out of my cups. I have broken 1 of them so far, and the impact deserved it, lol. They have held up great for me so far though.
Randy Caster is offline
Old 03-05-2009, 08:35 AM
  #4652
syndr0me's Avatar
Trader Rating: 32 (100%+)
What length CVD's does the world's kit come with in front? Maybe there's some correlation between the 44/46mm thing. The 44's do sit pretty shallow in the cups.
syndr0me is offline
Old 03-05-2009, 08:52 AM
  #4653
STLNLST's Avatar
Just because it hasn't happened to you yet doesn't mean it's not a problem. This sounds just like the problem with the hot bodies front knuckles. There are many that say we were doing something wrong because it's never happened to them. There's only one guy still diving a hotbodies at the carpet track now because of that. The gerneral public make better R&D guys than the factory guys when it comes to durability testing. You rarely make mistakes and because of that I now have a homie in the invite class this year You guys help figure out the best starting set up for the kits and camber link testing and shock location.....etc The public let's a company know where the weak links are. I just hope the problem is solved in a timely matter and the racers can go on running a great car See ya at the Reedy warm up race
STLNLST is offline
Old 03-05-2009, 09:03 AM
  #4654
TimPotter's Avatar
Trader Rating: 14 (100%+)
I have not had an issue with durability of the cups, but the short of it... The way things are, if you have one big collision, the drivers fault or not.. the car is a paperweight...
I ran mod at our last state race.. ( Kraceway..big gas track) And drilled some guy running 17.5 in practice... had to be a 30MPH difference in speed... didn't see him... , tore the front right corner of my car off, including the cup...
TimPotter is offline
Old 03-05-2009, 09:19 AM
  #4655
mickrcarver's Avatar
Trader Rating: 101 (100%+)
anyone have an extra diff for the 416, for sale in case i cant get the cups in time?
mickrcarver is offline
Old 03-05-2009, 09:59 AM
  #4656
Originally Posted by VTR View Post
guys, need so help,
what's e size of e pinion gear i shd use if i'm using a 3900Kv, 10T brushless motor? mine spur is 105T
thanks.
How big is youe track.. how much traction do you have ? I ran a 5.83 final on a 70x36 track and it was ballistic! and 10 turn brushless,,, umm that doesnt make any sence . Is it a 10.5 or not?
John St.Amant is offline
Old 03-05-2009, 12:27 PM
  #4657
TryHard's Avatar
Originally Posted by maxepower View Post
So, I wonder if TRYHARD is listening if he would know if the 415 delrin cups will fit the 416, maybe with a little modification? If so, I know there are aftermarket companies making them other than Tamiya. I had the same problem with the 415, they didn't sell the delrin cups seperately at first and you had to buy another spool just to replace the cups. That's when I found out about the aftermarket option. Once again Tamiya has issues keeping racers happy with the proper parts in stock, so if that's the case go to another source!
I'm here...
The 415 cups are different to the 416 ones, as I beleive they are a little wider between the bearings... however a little mod to the bearing holder, I'm pretty sure you can run them. Only issue I can see (and as I no longer have a 415, I can't check), is the fitment of the alloy sleeves. I have a feeling the 416's might be too short, and the 415's too fat at the bearing end...
Another option is using steel cups... I've run the ones from the TA05 spool (they fit, apart from needing to mod the bearing holder as above), and certainly won't break, and I've also run ones from Xceed. however, being a little heavier, they do take away a bit of steering. Still, as a stop gap until the plastic ones come in, the option is there.
All you need to get it to fit (and I'm sure I've mentioned this before), is take the bearing holder, and remove some material from the inner face, facing the bearing. It needs less than a mm to do, and a dremel cutting bit placed flat agains the face (i.e. sanding, not cutting) does the job in seconds.
I have to admit, I'm with Randy on the breaking cups issue though... I think I've only broken one in over a years racing. More often than not I have to replace them beacuse they're worn out!
Ed
TryHard is offline
Old 03-05-2009, 12:36 PM
  #4658
RC MARKET's Avatar
Originally Posted by TryHard View Post
I'm here...
Ed
What Xceed ?
RC MARKET is offline
Old 03-05-2009, 12:42 PM
  #4659
TryHard's Avatar
Originally Posted by RC MARKET View Post
What Xceed ?
Just checked, they are the xspede ones, found them on RC mart. they are for the 415 spool.
TryHard is offline
Old 03-05-2009, 12:45 PM
  #4660
TryHard's Avatar
actually, I've just rembered, the 415 cups HAVE to work with the bearing holders, as when I first got the car, I ran the 415 spool in it, with the pulley mounted the other side... there's yet another option...
TryHard is offline
Old 03-05-2009, 12:50 PM
  #4661
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by jonest View Post
I'm running 11.5 and couple of knocks on the barrier, it goes shattered!!!
geez..what kind of barriers are you guys using? solid concrete?
thats what im saying. im not a great driver...and ive had my own share of spectacular crashes.. sometimes full throttle...and nothing breaks. so you guys must be doing something really bad to break a spool cup. ive broken more rear arms (2) in the last 3 years than i have spool cups.
good thing i have spare cups because now that i've posted that... im gonna break one this weekend, watch.
Hebiki is offline
Old 03-05-2009, 01:03 PM
  #4662
AWK
AWK's Avatar
I will attest to that!!!!
I am the same way. i am in no way a great driver, and I have hit my 416 hard, once sheering the swing shaft right off at the axle and the spool was fine.
AWK is offline
Old 03-05-2009, 01:30 PM
  #4663
STLNLST's Avatar
You better knock on wood.... Now I know where to hit your car should you ever be in front of me at a race....
STLNLST is offline
Old 03-05-2009, 01:32 PM
  #4664
Hebiki's Avatar
id love to race against/with you at Reedy... but wont be making that race this year
Hebiki is offline
Old 03-05-2009, 01:35 PM
  #4665
STLNLST's Avatar
You can be there in spirit.....and you can send me your 416WE to run We'll see how durable the cups really are
STLNLST is offline
