Tamiya TRF416 / TRF416WE / TRF416X
#4561
#4562
mm, dont have pics atm, but it is very simple. when you take the arm side off the servo saver, you will see that the outer 2 springs are not flush with the molding. rotate the spring so that one side is flush and you will see how much play there really is on the other side. Simple cut a piece of thin card board (like the one from the tamiya packaging) and fill that space up. I used about three layers folded like an accordian. Hope this helps.
btw, anyone have the clearance between the top and bottom plates? don't have car atm.
#4563
hey does any one know how to get rid of excessive shaking in the front when i turn at low speeds. any help would be appreciated i got rid of some of it but not all and good advice on the servo saver i just switched to a plastic servo horn its got the extra give just in case
#4564
Although, if that so happens to be your problem, good luck trying to find some replacement outdrives! It appears, at the moment, the whole world is out of stock.
#4565
Check the spools plastic outdrives. They tend to prematurely fail after a few good whacks into the boards. I've found that when they start to wear out, the car starts to handle a little funky and it definitely adds extra chatter to the front end.
#4566
#4567
If it doesn't, what have you lost?
#4568
#4569
Anyhow since you mention outdrives I have broken it twice since, all on the right side of the spool. I m running full steering lock and our track is running anti clockwise and I hardly hit anything that hard. I also broke one CVD, again on right side without hitting anything, it happened during normal practice. I m thinking of using front diff now, and if I change to front diff do I have to use 42mm CVD as well?
#4570
#4571
Can someone please get the top deck clearance for the 416? Need to know if I can use a metal lipo tray with the batt I will be getting. Thanks
#4572
Hi
I have a tamiya 416 we, and goes with the short suspension arms.
Can anyone please tell me, or tell me where, I can find a list. So I can see which suspension blocks I need to combine to have any given Toe-in?
Sorry for my poor english, I hope you understand
#4573
look for the excel file at bottom.
now can I have my top/bottom deck clearance?
#4574
#4575
I explained this was disappointing because this is a high wear item that should be replaced regularly for maximum performance. He then suggested i might have better luck if i were to check out a few Japanese websites. Even worse, they too were also out of stock!
Ultimately, I had to resort to purchasing a couple of complete spools for about $60.00 just to get a few STINKING plastic outdrives
P.S. Could you please give me the contact info to your local hobby shop?
Thanks, Chris
