Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 01-15-2009, 04:32 AM
  #4006
veecee's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Kalel
I just wondering if anybody can tell me is there any front differential part for TRF 416? What is the part number for it? Thanks
Same as rear diff.
veecee is offline
Old 01-15-2009, 05:46 AM
  #4007
Originally Posted by veecee
Same as rear diff.
Kalel is offline
Old 01-15-2009, 05:52 AM
  #4008
JCarr's Avatar
Originally Posted by BlackedOutREVO
So over all, how much stuff has broken? I mean, thats it. Or have you broken casters, and knuckles here and there?
The only thing I have had to replace on the car was a bent screw. I did get the car second hand though and didn't think about the other parts being replaced already. I know I have put the car through a serious torture test and it is very tough.
JCarr is offline
Old 01-15-2009, 05:54 AM
  #4009
I am thinking of getting the 416 and would like to know which kit I should get the 416 reg or the 416 world kit and what is the largest lipo pack can be use in either kit, do I need any other hopup for these kits or it is fine as is any info would be appreciated.
Ramyuras is offline
Old 01-15-2009, 06:00 AM
  #4010
TimPotter's Avatar
Trader Rating: 15 (100%+)
I would suggest the 416WE, it has all the optional parts that people are running on thier original 416. I have been running the SMC 5000 28c pack, and it fits right in...
TimPotter is offline
  #4011
an SMC 5000 lightning volts is going to be the fastest thing u can put in there .. but the deans connector sucks..
John St.Amant is offline
Old 01-15-2009, 06:08 AM
  #4012
Thank you guys.
Ramyuras is offline
Old 01-15-2009, 06:49 AM
  #4013
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Originally Posted by STLNLST
He made me a deal that I couldn't pass up. Basically he made my mind up for me
First Orion, now Tamiya... you stalking me?
Randy Caster is offline
Old 01-15-2009, 06:52 AM
  #4014
Originally Posted by dameetz
A friend of mine got a 416WE, on the very first drive he broke the front plastic drive cup from the stock solid diff without hitting anything. Does tamiya or any other company has an upgrade for this? At the moment he's opted to get a normal diff up front which has aluminium drive cup.
That seriously seems like a fluke... I have chipped the outer edge of one when I bent an aluminum bone on a hard hit, but I haven't been able to brake one of the plastic cups. As of this time nobody I know of has an upgrade for the stock one, I would suggest he put a new outdrive on it and try again, with the aluminum outer sleeve it should be extremely durable.
Old 01-15-2009, 08:12 AM
  #4015
dameetz's Avatar
Any suggestion on which connector is good or better that deans? All my packs are deans and i m thinking of trying the Traxxas connector. By the way is intellect 3800 35C a good battery?
dameetz is offline
Old 01-15-2009, 08:14 AM
  #4016
dameetz's Avatar
Thanks for the advice. Will this fit? http://www.rcmart.com/catalog/rc-evo...th=595_744_710
dameetz is offline
Old 01-15-2009, 08:30 AM
  #4017
Adam?'s Avatar
Originally Posted by doriftu
Adam,
how do you remove the shoo goo? What solvent you use or u just yank them out?
In the past, I've been able to just peel them off with some force. The shoo goo can be removed from the case by hand. It does tend to discolor the plastic a bit. The trick is to try and not bend your weights so you can reuse them down the road.
Lots of activity in this thread lately. It's good to see more interest in this car stateside. Perhaps other hobby shops will start stocking more parts. I mentioned to Stormer that I'd love to buy parts from them, and they said they've been considering carrying 416 stuff, so we'll see.
Adam? is offline
Old 01-15-2009, 08:47 AM
  #4018
JCarr's Avatar
I hope they do, I would probably get all my parts from there.
JCarr is offline
Old 01-15-2009, 09:58 AM
  #4019
STLNLST's Avatar
Trader Rating: 32 (100%+)
It looks that way huh Orion sponsors me so I followed you there but Tamiya hasn't shown any love I had BMI too but after I left Schumacher and he stopped doing TC stuff it went away Maybe I'll lock my keys in my car with it running and complete my Caster transformation
STLNLST is offline
Old 01-15-2009, 10:22 AM
  #4020
Make sure that the 44mm driveshafts are in the front or the spool outdrives will break in notime.
Mr_Orange is offline
