Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 01-08-2009, 11:17 PM
  #3901
Stein Tumert's Avatar
Originally Posted by MDawson
Which brace are you referring to as the 'cut brace'?
Btw, great site!
The small separate top deck piece at the rear of the 416. The 416 WE edition has a one piece top deck and not 2 separate pieces. You can cut the old one to get a similar effect (or buy a new one piece one)
Stein Tumert is offline
Old 01-09-2009, 05:28 AM
  #3902
Originally Posted by mok
my experiences have been that 0.5-1.5 is safe, but 2mm of spacers I would not..
(this has all been with rubbers on either carpet or asphalt)
i have been using speedmind, vtec, much more, tamiya and sorex rims with anywhere up to 1.5mm of spacers and never had a wheel come off..
i've got a tendency to believe that as long as about 1mm of wheel hub goes inside the rim then you should be ok (freak occurances aside )
i think realistically though, if you want 1mm or more of spacers then you should be moving to the 6mm hubs
-Mark
Thats right ! I had spacers on my rear wheels at Region 5 and I got clipped by a backmarker and off t came .. Cost me the main. lol
John St.Amant is offline
Old 01-09-2009, 06:11 AM
  #3903
Trader Rating: 27 (100%+)
Originally Posted by maxepower
Hey Mark,
What's up? I thought you were running Kyosho! Welcome back to the "DARK SIDE". Or is it the Dark blue side. Yes, TRYHARD'S website is excellent for info on the 416 and the 415.
Ha! Dark blue would be a Yokomo/AE. Happy New Year
Thanks Stein. Which top deck do you prefer in the low bite tracks that you might run on?
MDawson is offline
Old 01-10-2009, 08:29 PM
  #3904
Vicko's Avatar
Trader Rating: 14 (100%+)
hey can anyone tell me where can I find info on what the 008 or 009 spring
are in lbs? they are marked 2.2, 2.4 , 2.6 but I would like to know what
they are in lbs.
Vicko is offline
Old 01-10-2009, 09:06 PM
  #3905
JimmyMac's Avatar
They should be on the XRay website. They give "guess-ta-ments" on what they are or what they are rated between.
JimmyMac is offline
Old 01-10-2009, 09:09 PM
  #3906
adamge's Avatar
Apparently someone actually measured like every TC spring on the market and put the data into one table. This guy's numbers on new vs. old Xray springs don't agree at all with Xray's comparison chart.
adamge is offline
Old 01-10-2009, 10:35 PM
  #3907
If those measures are from Ling Tong, he used spring gauge at the engineering company he works at. High confidence that he got it right.
MDawson is offline
Old 01-10-2009, 10:54 PM
  #3908
Korey Harbke's Avatar
Btw, great site!
The rare endangered species of Markus Dawsonis lives!!!! Hows it goin man???
-Korey
Korey Harbke is offline
Old 01-11-2009, 12:20 AM
  #3909
mok
mok's Avatar
the Ling Tong ones are on Ed's website in the "universal spring chart"..
http://www.thard.co.uk/viewtopic.php?f=24&t=33
i trust these measurements without a doubt..
consistency in the testing method at least shows me which ones might be a good choice from what i currently use etc
mok is offline
Old 01-11-2009, 01:57 AM
  #3910
I now always run a one piece topdeck on my "old" 416. Got it from a company in Finland, you find it if you check back on this thread from last fall. Excellent service, had it 2 days.
Old 01-11-2009, 02:17 AM
  #3911
CraigM's Avatar
Trader Rating: 34 (100%+)
v-dezign. I have it too
CraigM is offline
Old 01-11-2009, 06:39 AM
  #3912
sohlman's Avatar
Trader Rating: 92 (100%+)
MR is using the older two piece top deck at the DHI Cup...
Attached Thumbnails Tamiya TRF416 / TRF416WE / TRF416X-sat-rheinardcar-2.jpg
sohlman is offline
Old 01-11-2009, 07:34 AM
  #3913
-Korey
Happy New Year Korey. Shouldnt you be at Novak or something like that
PM me. Look forward to catching up.
MDawson is offline
Old 01-11-2009, 10:14 AM
  #3914
Hi Mark, good to see my archnemesis from the 2004 worlds driving a real car for a change
Yes, and the rear piece appears to be cut through the middle.
tonyv is offline
Old 01-11-2009, 10:58 AM
  #3915
Adam?'s Avatar
He's also not running a screw in the center brace.
Adam? is offline
