Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 11-30-2007, 05:33 PM
  #376
TryHard's Avatar
Originally Posted by veecee View Post
Found some nice close-ups from the Hobby Show:
http://www.rcmodel.com.hk/leobbs/att...5751&type=.jpg
http://www.rcmodel.com.hk/leobbs/att...5843&type=.jpg
Looks like the steering components will be well clear of the belt.
Can't see the pics, as I can't log into the site... any chance of saving them and posting here?
Cheers
Ed
TryHard is offline
Old 11-30-2007, 07:20 PM
  #377
surrealmaterial's Avatar
Cheers
Ed
same here cant see them either
surrealmaterial is offline
Old 11-30-2007, 07:30 PM
  #378
JRRobiso's Avatar
Arrow
Cheers
Ed
ditto.
JRRobiso is offline
Old 11-30-2007, 11:34 PM
  #379
veecee's Avatar
Trader Rating: 34 (100%+)
Sorry guys. Try this first: http://www.rcmodel.com.hk/leobbs/pos...c=990&postno=7
Then click on the pics to get the full hi-res shots. Lazy aren't I...
veecee is offline
Old 11-30-2007, 11:48 PM
  #380
syndr0me's Avatar
Trader Rating: 32 (100%+)
Zing!
Attached Thumbnails Tamiya TRF416 / TRF416WE / TRF416X-img_9179_1192145932.jpg   Tamiya TRF416 / TRF416WE / TRF416X-img_9175_1192145843.jpg   Tamiya TRF416 / TRF416WE / TRF416X-img_9174_1192145751.jpg   Tamiya TRF416 / TRF416WE / TRF416X-img_9169_1192145485.jpg
syndr0me is offline
Old 11-30-2007, 11:55 PM
  #381
syndr0me's Avatar
Some older pictures...
Attached Thumbnails Tamiya TRF416 / TRF416WE / TRF416X-416over2.jpg   Tamiya TRF416 / TRF416WE / TRF416X-416over.jpg   Tamiya TRF416 / TRF416WE / TRF416X-416det2.jpg   Tamiya TRF416 / TRF416WE / TRF416X-416det.jpg   Tamiya TRF416 / TRF416WE / TRF416X-416_5.jpg
syndr0me is offline
Old 11-30-2007, 11:56 PM
  #382
syndr0me's Avatar
A few more...
Attached Thumbnails Tamiya TRF416 / TRF416WE / TRF416X-416_1.jpg   Tamiya TRF416 / TRF416WE / TRF416X-416_2.jpg   Tamiya TRF416 / TRF416WE / TRF416X-416_3.jpg   Tamiya TRF416 / TRF416WE / TRF416X-416_4.jpg
syndr0me is offline
Old 12-01-2007, 12:57 AM
  #383
Blueman Austria's Avatar
Looks like it came with the rev. lightweight arms. Only the C-hubs steering arms and the rear uprights are new.
The swing shafts are 45mm instead of the 46mm. Maybee the 46 ones fit also.
The suspension blocks, -shafs, are also usable form the 415/evo series.
Thats makes my decision easy ! I want it!!!!!!!!
Blueman Austria is offline
Old 12-01-2007, 02:03 AM
  #384
the link works thanks guys
Old 12-01-2007, 03:50 AM
  #385
TryHard's Avatar
Originally Posted by RC Champ
Dear Mr.Clark
Hello,sir.
Yes that is correct,Tamiya changed releasing date for the TRF416 to the 13rd of December.
And its advertisement issued at latest RC World magazine,this says specifications for the TRF416 will be as follows.
Carbon graphite lower deck (2.5mm)
Carbon graphite uppder deck (2mm)
Aluminum motor mount (Mounted 5mm backward compare to the TRF415)
Front & rear bulkhead (Narrower than TRF415)
Aluminum steering arms
Aluminum air duct!
Front one-way
Rear ball diff
Aluminum diff joint
38T Front and Rear pulley
18T Center pulley
TRF Special damper
Reversible suspension arm
New Front & Rear uprights with 1050 ball bearing
Front & Rear universal swing shafts
Front & Rear stabilizer
Aluminum turnbuckle shafts
This advertise says the Aluminum air duct will come with the TRF416.Shall I cancel your 3454480 Air duct?
If you have any question,please let me know,sir.
Thank you.
Best regards,
RC Adviser Champ
Hirotaka Suganuma
13th it is for a Japan release looks like they might have been wrong on the air duct front though
TryHard is offline
Old 12-01-2007, 11:40 AM
  #386
miccal's Avatar
Trader Rating: 23 (100%+)
Thanks Ed, keep it coming!
miccal is offline
Old 12-01-2007, 03:17 PM
  #387
syndr0me's Avatar
Is it known if this kit will have new sway bars? If they're the same, what's the part number(s)? Any special release sways out there in different colors?
syndr0me is offline
Old 12-01-2007, 05:14 PM
  #388
TryHard's Avatar
don't know in honesty... It looks like they are the same ones from the TA05... which are the ones used in the MRE/MSXX.
TAM53842 is the standard coloured kit (red, yellow, blue), TAM49383 is the all black set. Both sets are the same rates mind (soft, med, hard).
HiH
Ed
TryHard is offline
Old 12-04-2007, 11:36 PM
  #389
Exclamation Setup Sheet
who ist the Setup sheet from Rheinard Marc (JMRCA)?
GONZO
Team GONZO is offline
Old 12-05-2007, 01:06 AM
  #390
mac853's Avatar
GONZO
Wow, just now you want the setup sheet, i think is too early.
Maybe will show up in Tamiya website after the chassis release.
I hope also a lots of option parts release, specially for the spool. If not release in short moments by themselves nor aftermarkets, i may order to make 1 by some workshop.
mac853 is offline
