Tamiya TRF416 / TRF416WE / TRF416X
#3706
Stein, your track is quite big and open. You can take advanatge of the extra power, however at our track it is much tighter and not nearly as open. You can see in the pic below...
I have tried the one-way vs the spool and came to the conclusion they are just as quick as one another, only difference being consistency. Over a 5-min run I am much faster with a spool, not to mention racing against someone is much easier, allowing for overtaking maneuvers that require brakes. For your track I would probably switch to a oneway but at our track it is not an advantage.
#3707
I have had a few PM's from people who were confused about the location of the "vent hole" on my shocks so I decided to take a picture of one. Hopefully this will clarify things.
#3708
What size drill bit did u use there? about 1mm??
#3709
#3710
#3711
What the biggest pinion (48 pitch) I can run? I run 75 tooth at the moment but Im going to try abit of mod action for fun. Thanks in advance.
#3713
Sorry guys, I meant spur gear.
32 tooth pinion would fry a 4 turn motor for sure.
#3715
I am 5 mins away from Whalan so I will be practising alot during the holidays to be on your pace on 10.5 in the big meets
#3718
Just posted some more pics if anyone wanna see more of the World Edition...
http://kentech.blogs.se/
#3719
right guys, I've just uploaded the new spring data to the website, thanks to Linger for the values.
Link here... http://www.thard.co.uk/viewtopic.php?f=24&t=33
And as a project for this weekend... I'm going to attempt to draw up a roll centre calculator for the 416, such as I did for the 415 (attached below). Ahh, lazy weekend before christmas
Cheers
Ed
Cheers
Ed
#3720
