Tamiya TRF416 / TRF416WE / TRF416X
#3661
i noticed the "vent hole in shock cap".
I have never heard of this before.
Could you explain me where this idea comes from, what the advantages are?
Also: Fastcats Grandslam: I guess this is a carpet-track?
#3662
Drilling that hole minimizes the pack and also will eliminate rebound issues not warrented for oohhh ,, u almost got me ..lol..
no really its for limiting pack.... and rebound.
Some times guys use o-rings or eurithane inside the shock bladders too.
#3663
john, you exactly right. I use this trick to eliminate most of the rebound which is ideal for higher grip situations. Why it suits higher grip is it will help keep the car from traction rolling, making the car less responsive and more forgiving. Some people eliminate rebound by bleeding oil, however I find it is nearly inpossible to build four completely identical shocks when air is present in the shock. With the vent hole, the "pack", or air that was once trapped between the cap and bladder, no longer effects the rebound. So now I have very little rebound compared to before and have the benefit of air free shocks which last a WHOLE race weekend...or longer depending on grip level.
Now some may wonder, "how can I fine tune rebound with a vent hole?". You can do this by purchasing, making(cutting those crappy red foam pieces included in your shock baggies), or using left over o-rings from the build to adjust the space between the cap and bladder to give you the desired effect.
Hope this was clear for eveyone, people I have built shocks for in the past seem to prefer this method as well, a typical responce being "my car was butter smooth and the shocks last forever!". For those who plan on trying this, plz leave some feedback.
Cheers!
Cheers!
#3664
....and yes Fastcats is a indoor carpet track.
#3665
yup, spot on
Most setups quote ir like you say, with 5mm and 4mm... whats slightly confusing is that a smaller number actually equates to more droop...
The most accurate way of measuring droop is actually to remove the wheels and tyres, then place the car on a flat plate and measure up to the axles. This way you can keep it consistent from tyre to tyre (they all have slightly different diameters)... and is good for Foam.
David Junn explains the method in more detail here http://www.thard.co.uk/415/tips/DavidJundroopmethod.doc
HiH
Ed
HiH
Ed
#3666
#3667
Corey, did you use the soft IFS c-hubs for durability, or for tuning? I've noticed they tend to yield a lot more steering.
#3669
Much More makes a set of foam to go above the bladder, its perfect for anyone wanting to try out different rebound settings using Corey's vent hole method.
Doriftu - I've never measured droop like that, but I'd imagine you would want the shocks off of the car since generally one spring will have more pre-load than the other.
#3670
thx adam, I used the c-hubs to get more steering. The durability is just a bonus
it was a perfect run, after mike pulled off I didn't really push the issue. I felt it had a 11.8 in it...oh well
#3671
Good running this weekend Corey-
#3672
Hupo Reedy setup..
Here is Hupo H set up from the 2008 Reedy Race
Front
middle hole on Tower
Tamiya 400 Wt 3 hole pistons
3.5mm under camber link in middle hole
Furthest hole on A arm
4mm hex hub .5mm spacer
416 D front and 416 d rear flat
HPI silver spring
5mm ackerman
.5mm bump steer spacer
droop 6
arm spacing 2 mm front 2mm rear
Rear
3rd hole out on tower
Tamiya 400 wt 3 hole pistons
3.5mm under camber link middle hole
3mm spacer outside hole rear hub
HPI Blue spring
2nd hole outside on a arm
4mm hex hubs
1xa rear front 1d rear
mazda speed 6 body
arm spacing 3mm front 1mm rear
Front
HPI silver spring
5mm ackerman
droop 6
Rear
HPI Blue spring
4mm hex hubs
mazda speed 6 body
#3673
#3675
not only that but then are your shocks allowing the full droop as well?
