Tamiya TRF416 / TRF416WE / TRF416X
#3572
My English teacher at school would be ashamed of me
Really got to start reading what I type.
Silver Cans don't fit without modifying the standard motor mount, I think the end of the motor (pinion side) is too wide or long. The machinist who modified the original mounts at our club from what i've heard set up a jig to manufacture a complete mount.I'll try to get a sneaky photo of the prototype on Wednesday.
Thanks burbs for the clarification above
you were on the money
#3573
#3574
Ok, it's taken a few days, but I'm about to tear my car down and try a completely different setup, so before I do I'll post the setup from Bending Cornerz that a few people have been asking for.
The track is a small tight outdoor asphalt track, medium grip.
FRONT
Upper Arm Position: 3
Upper Arm Spacer: 2mm
Damper Position: 2
Lower Arm Position: 1
Sus. Mount Spacer: F=.5mm R=1mm
Camber: 1.5*
Ride Height: 5.4mm
Rebound: 100%
Front Drive: Spool
Stabilizer: 1.5mm
Wheel Hex: 4mm
Wheel Spacer: .5mm
Piston: 3 Hole
Oil: 550
Spring: HPI Pink
Front Pulley: 36 Tooth
REAR
Upper Arm Position: 1
Upper Arm Spacer On Hub: 2mm
Damper Position: 5
Lower Arm Position: 2
Sus. Mount Spacer: F=0 R=0
Camber: 1*
Ride Height: 5.6mm
Rebound: 100%
Stabilizer: 1.4mm
Wheel Hex: 4mm
Wheel Spacer: .5mm
Piston: 3 Hole
Oil: 550
Spring: HPI Blue
GENERAL
Front Toe Angle: 0*
Front Sus. Mount F=C R=C
Rear Sus. Mount F=XA R=D
Upright Spacer: .5mm
Steering Spacer: 4mm
Rear Hub Spacer: .5mm
Center Pulley: Direct
Front Sus. Arm Spacer: 2.5mm
Rear Sus. Arm Spacer: 3mm
Lower Deck: 2.25mm
Body: Protoform Mazda 6 LW, 6mm Forward
Tire: Sorex 36R
I believe this is all off of the original Tamiya setup sheet, I downloaded it off of Ed's website.
Ed - Feel free to post this setup on your site if you'd like.
FRONT
Damper Position: 2
Camber: 1.5*
Ride Height: 5.4mm
Rebound: 100%
Front Drive: Spool
Stabilizer: 1.5mm
Wheel Hex: 4mm
Wheel Spacer: .5mm
Piston: 3 Hole
Oil: 550
Spring: HPI Pink
REAR
Damper Position: 5
Camber: 1*
Ride Height: 5.6mm
Rebound: 100%
Stabilizer: 1.4mm
Wheel Hex: 4mm
Wheel Spacer: .5mm
Piston: 3 Hole
Oil: 550
Spring: HPI Blue
GENERAL
Front Toe Angle: 0*
Lower Deck: 2.25mm
Tire: Sorex 36R
#3575
randy.
2 questions if you don't mind.
-do you typically build your shocks with 100% rebound?
-are you running or do you ever run the short arms?
#3580
yeah, and the brand of paint!!
#3581
What other items would be recommended to purchase if buying a 416WC to allow a good ability to tune for different tracks. I'm not talking spares, just tuning.
I've noticed there are short arms, different pulleys and all that crap. I run stock and super stock quite competitively and like to be able to tune to different tracks. I've steered away from Tamiya because it seems a racer needs almost a whole different version for each track.
This car does appeal to me, but I'm just worried it will be an expensive change with not much results.
Cheers
Aaron
Cheers
Aaron
#3582
is there anyone that have good tips for the Tamiya TRF 416 spool?
#3583
Anyway, why you guys put the 416 on the 540 race.
What i meaning is 416 is too much high-class running just 540, just because even we are 23T/4000kv race after the banning of 540 in our series, someguys are still running ta05 and 415msxx, then their result are not so worse then sometimes better than the higher performance and newer chassis, EX:Cyclone and 416.
#3584
i race in Australia at SMA and nobody runs a 416 in 540 class. I have a 415msx and there is a couple of them and cyclones and other like ta05, the only reason i dont have a 416 is because the motor doesnt fit and the 415msx does me well. the guy who wins most of the time runs an original 415. maybe nexy year ill get a 415we when i step up to stock
#3585
Craig, come down to the track tomorrow night with this setup and we can use it as reference!
