Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 11-26-2008, 11:47 AM
  #3436
Trader Rating: 38 (100%+)
Originally Posted by RC MARKET View Post
WC around next week arrive !
How much in USD?
or8ital is offline
Old 11-26-2008, 12:01 PM
  #3437
RC MARKET's Avatar
Originally Posted by or8ital View Post
How much in USD?
weekend will have price !
RC MARKET is offline
Old 11-26-2008, 12:29 PM
  #3438
Adam?'s Avatar
The top deck looks like it would block the plugs on lipo batteries like the Orion. Is that the case? Do you have to hang the battery off the side to get it to work?
I haven't checked them all, but it does block the Orion style plugs slightly. You could probably notch the top deck to make it work.
I use the SMC packs with the top wire, and it works out really well. The 5000's fit with a tiny bit of clearance, but the 4000's are great. I'm using a PPZ plate under mine.
Adam? is offline
Old 11-26-2008, 01:20 PM
  #3439
yyhayyim's Avatar
Trader Rating: 26 (100%+)
How much in USD?
how much for shipping?
yyhayyim is offline
Old 11-26-2008, 01:54 PM
  #3440
CraigM's Avatar
Trader Rating: 34 (100%+)
WE on redrc
http://www.redrc.net/2008/11/tamiya-...on/#more-12854
First I've heard of the suspension blocks being "lower", sounds a bit off the mark to me
CraigM is offline
Old 11-26-2008, 02:22 PM
  #3441
94eg!'s Avatar
Trader Rating: 17 (100%+)
Your reading it wrong. They are saying those are the "lower suspension brackets"...
Not "the suspension brackets are lower"...
94eg! is offline
Old 11-26-2008, 03:26 PM
  #3442
CraigM's Avatar
oh the shame... sorry it was early morning when I read that
CraigM is offline
Old 11-26-2008, 03:44 PM
  #3443
Hebiki's Avatar
on my original 416... i used the dremel drum sanding tool to remove a little bit of the upper deck so the orion plug slides in perfectly. i also removed a little bit of the cross brace so that i could fit my 57T pinion when i run 17.5
Hebiki is offline
Old 11-26-2008, 04:37 PM
  #3444
doriftu's Avatar
I am just curious - are the bulkheads in the 416 aluminum 7075?
thanks
doriftu is offline
Old 11-26-2008, 05:30 PM
  #3445
Originally Posted by motorhead68 View Post
DOES TAMIYA HAVE A TOURING CAR SPRING THATS AROUND 25# RATING??
ANY INFO WOULD BE GREAT THANKS..
I'm not sure what the weights are but if you look there are a gray and a purple springs... hard and extra hard. in that order.
John St.Amant is offline
Old 11-26-2008, 07:01 PM
  #3446
StickyFingaz's Avatar
Trader Rating: 17 (90%+)
Does anybody have any experience with the EVO 5 MS? Given it's shaft drive design, i'm thinking of building one up as my Stock Class killer.
I got a 416 right now, and instead of getting rid of it and getting the new WE, I'm thinking of just upgrading a few parts on it (motor mount, topdeck... no lower chassis since i'm running lipo anyway) and saving up for an EVO 5 instead. Suspension parts are the same, the only addition to my spares would be drivetrain related.
Thoughts?
(Sorry to threadjack)
While I have you guys here, I'm probably gonna replace my lower chassis on the 416 soon. Original vs. thicker vs. new chassis with different battery placement????? Now i've got three of them to decide on... help!
StickyFingaz is offline
Old 11-26-2008, 08:38 PM
  #3447
auzzy_mate's Avatar
Only for Stock. My brother used a 13.5 in there and ran it with not much success. The torque being put on the chassis etc etc was a little too much for the plastic gearing to handle inside the front and rear diffs.
Ben
auzzy_mate is offline
Old 11-26-2008, 10:02 PM
  #3448
That was a seaious issue wasnt it ! Maybe tyhe new chassis fixxed that issue . All it needed was a bouble ball bearing at either end if the center shaft.
Old 11-27-2008, 12:02 AM
  #3449
Trader Rating: 21 (100%+)
For Orion style packs with the bullet plugs, try putting the pack in with the plugs to the back. IP3800's worked with the pack all the way to inside and the plugs to the back. Just make sure you run the wire right to clear the belt and spur. No need to dremel anything.
Brian L is offline
Old 11-27-2008, 12:12 AM
  #3450
Blueman Austria's Avatar
Ben
I run a normal "Evo5" and have absolutly no issues with my 13,5 Motor. Also the gears holdup very well (stripped one fornt in 3 years of racing).The last training session i made a beck to back conversation with my 415MSXXMRE and the fastest laptime of the day i runned with the Evo.
Another question: Is the 1F block 0,5 deg. wider than 1E? I read that the World edition comes with XA and F rear. Then this will be 3,5° toe in. .
Greetz Blueman
Blueman Austria is offline
