Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 10-22-2008, 03:09 PM
  #3061
TryHard's Avatar
http://gallerie.automodelisme.com/di...740&fullsize=1
New motor mount can be seen there, easily distinguisable if you look how the forward central brace is mounted, much higher up on the mount.
Ed
TryHard is offline
Old 10-22-2008, 03:29 PM
  #3062
Adam?'s Avatar
We all knew from the beginning the original motor mount was designed to be/look as chunky as possible so they had something to upgrade on the next version of the car. I'm shocked, SHOCKED to see it here now. I may have to buy a whole new kit just so I can get that sexy little thing. Maybe they can use some of that left over aluminum on the toe blocks. :-)
Adam? is offline
Old 10-22-2008, 04:22 PM
  #3063
Originally Posted by CraigM View Post
well a 13.5 setup probably wont be the same as marcs mod setups, but there are a bunch of good rubber and carpet setups on www.thard.co.uk
Don't think the Euros or Andernach ETS set ups ever saw the light of day but from what I saw they weren't greatly different from the reedy race ones. If you have C/C up front, XA/E on the rear, and 3mm under every camber link then you are pretty close to spot on for rubber
Andernach ETS set up? Here http://www.petitrc.com/reglages/tami...miyaTRF416.htm
Arn0 is offline
Old 10-22-2008, 04:38 PM
  #3064
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by dragracer72nova View Post
I am looking for the Same for Setups(13.5/Rubber/Lipo)
Dave
sent you that set up. YGPM
Hebiki is offline
Old 10-22-2008, 09:29 PM
  #3065
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Arn0 View Post
Yeah I have seen Dai's setup before but I'm pretty sure Jilles and Marc were using hole 3 for their front and rear camber links. If anyone has access to either Andernach or euros set ups it'd be awesome to see what they were doing. I studied the pictures from the ETS galleries and their geometry set ups are very similar to Eds east london (and my SMA one), I'd love to know what they are doing with shock oils and rebound though (though I did notice 1 oring front and rear on jilles shocks)
CraigM is offline
Old 10-22-2008, 11:53 PM
  #3066
Low_E's Avatar
an O-ring on the shocks? Is this on the exterior-side of the piston-shaft (I can't image you could notice them otherwise)? What's the purpose of this O-ring?
Low_E is offline
Old 10-23-2008, 02:36 AM
  #3067
CraigM's Avatar
Yes outside on the shaft. it's for setting the rebound: 1 oring = 2mm, 2 orings = 4mm
CraigM is offline
Old 10-23-2008, 03:36 AM
  #3068
auzzy_mate's Avatar
Hope you guys don't get mad about all my questions ... but could you please post some pictures of this Lipo tray into your 416?
thx!!
Here you go!
Attached Thumbnails Tamiya TRF416 / TRF416WE / TRF416X-tray1.jpg   Tamiya TRF416 / TRF416WE / TRF416X-tray2.jpg   Tamiya TRF416 / TRF416WE / TRF416X-tray3.jpg   Tamiya TRF416 / TRF416WE / TRF416X-tray4.jpg
auzzy_mate is offline
Old 10-23-2008, 12:27 PM
  #3069
Trader Rating: 40 (100%+)
stupid question. Does the c hub from T2008 fit it the TRF 416? I broke my c hubs last night and LHS doesn't carry much Tamiya parts.
joech is offline
Old 10-23-2008, 01:05 PM
  #3070
hey there aussie m8..
that looks like a nice piece but ..
would u please tell me why i would want to put the pack so far out?
seems to me we need to quicken the polar moment... not slow it down.
furthermore.. y doesnt someone just make us some tungsten rectangles to make the lipos weigh the same as nimhs?
John St.Amant is offline
Old 10-23-2008, 01:36 PM
  #3071
The advantage would be less weight is needed to balance the car. So you get a balanced car at a lower weight compared to running NiMH batteries.
Problem I see with this design is that during left hand corners the car will bottom out much sooner than during right hand corners. This will also make the cars ability to cope with kerbs and dots different between left and right hand side.
tonyv is offline
Old 10-23-2008, 01:41 PM
  #3072
My car is nicly balanced not only left to right but front to back. It took some doing but it drives beautifully. Guess you gotta be carefull where you put 6 oz. of lead. No manufacturer seems to think heavy rectangles that fit under the car would be profitable. HELLO!?..... ANY BODY THERE!?! guess not.
Old 10-23-2008, 02:09 PM
  #3073
94eg!'s Avatar
Trader Rating: 17 (100%+)
I could have sworn somebody sold those rectangle weights that fit in the battery slots. I think they were covered with a carbon-fiber-look film as well. I'll keep looking...
94eg! is offline
Old 10-23-2008, 02:16 PM
  #3074
94eg!'s Avatar
I knew it. Nexus racing used to sell them. They are currently listed as out-of-stock. I don't know if they are planning on making more or what, but you can always try to e-mail or call to find out. They only add 1oz for the set of 6 because they are so thin (chassis only a couple mills thick). This is why they are not a popular product...
http://nexusracing.net/newsdesk_info.php?newsdesk_id=60
94eg! is offline
Old 10-23-2008, 02:27 PM
  #3075
LOL those weights are only .2 oz. each and are made for golf clubs.. useless in my book.
