Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 07-06-2008, 08:49 PM
  #2476
prime's Avatar
Default Tamiya tuned springs
Hi all,
Just after some tamiya knowledge, i purchased a set of the tamiya springs 53440 in the soft (red), medium (yellow), stiff (blue) and ex stiff (white) i was wondering if anyone could tell me the actual LBS of each of these. Any assistance would be appreciated.
thanks
Pete.
prime is offline
Old 07-06-2008, 09:06 PM
  #2477
syndr0me's Avatar
Trader Rating: 32 (100%+)
Are there any reasonable carpet setups online that use the stock arms/blocks? I used a variation of the kit setup before, but it doesn't seem to actually be on a sheet anywhere.
syndr0me is offline
Old 07-07-2008, 03:01 AM
  #2478
TryHard's Avatar
Originally Posted by prime
Hi all,
thanks
Pete.
http://www.thard.co.uk/viewtopic.php?f=24&t=33
TryHard is offline
Old 07-07-2008, 04:03 AM
  #2479
prime's Avatar
Default springs
TryHard
Thanks for the link, but is the 53440 set the short or normal length springs??
thanks
Pete
prime is offline
Old 07-07-2008, 04:12 AM
  #2480
Stein Tumert's Avatar
TryHard
thanks
Pete
Normal
Stein Tumert is offline
Old 07-07-2008, 04:28 AM
  #2481
prime's Avatar
Default springs
cheers guys
prime is offline
Old 07-07-2008, 04:34 AM
  #2482
TryHard's Avatar
Originally Posted by Blueman Austria
@Ed!
Hy! I compared your setup with the manual of the 416, and i see that you give 3mm spacers in the rear (at the bulkhead and also the upright) instead of 0,5mm.
How does that affect the handling? is it a better choice for any type of surface? (tarmac and carpet).
At the front you lowerd the inner (bulkhead) one from 5 to 3mm. This should raise the rollcenter. Right?
I dont have a 416 but a 415MSXX MRE07, so the benefits should also work on my car?
THX in advance, Blueman
Hi Blueman,
Hebiki asked the same question before, and this is what I answered with;
I have to say that the 415 indoors always seemed to prefer the higher rear link, as it seemed to help smooth the rear car out. Seems the 416 likes it too.
Was chatting to an xray racer today, who had 4mm under his rear outer link, and was loving life... seems to be a trend for quite a trend on a number of car atm.
HiH
Ed
TryHard is offline
Old 07-07-2008, 06:06 AM
  #2483
tc3team's Avatar
Hi all,
thanks
Pete.
This link should help you out fella...
http://www.petitrc.com/reglages/1-10...pringChart.pdf
hth
tc3team is offline
Old 07-07-2008, 06:26 AM
  #2484
sakaguchinet's Avatar
Hi,
Tamiya is going to release new suspension arms:
51353 TB-03 Stock Suspension Arms (will be like 53928) only softer and cheaper material).
Finally the new sus blocks are available. But I am looking for the new blue titanium turnbuckles.
sakaguchinet is offline
Old 07-07-2008, 07:17 AM
  #2485
buboy28's Avatar
Originally Posted by sakaguchinet
Hi,
you have pictures of those blue titanium turnbuckles
buboy28 is offline
Old 07-07-2008, 08:08 AM
  #2486
Default TA-05MS, anyone?
Currently i am racing with a TA-04S. But am considering a new ride. I am just a bit curious. The price tag of the TRF 416 is only slightly higher than TA-05MS. Why do so many people opt for the TA-05MS? What is the difference between the two? I have seen some baseline TA-05 keeping up the pace with a couple of TRF 416s. These drivers are just average Joes, including myself. What advantage does the TRF 416 (aesthetic appeal? just for show?) have over the TA-05MS? Tell me your views. If i am convinced, i am prepared to fork out a bit more to buy TRF 416. Thank you.
Kiowa is offline
Old 07-07-2008, 09:59 AM
  #2487
Toughbeard's Avatar
Originally Posted by Hebiki
based off your quotes... Ed is saying adding it on the bulkhead OR the outer hub. NOT both?
By changing the inner and outer differently you alter both the Roll Center and the camber change.
By Changing both the inner and the outer the same amount you just play with the R/C not the camber Change.
So, If you found a good setup where you like the cars handling and the tire wear is good, but you want to smooth it out or sharpen it, you raise or lower both the inner and outer... keeping the diffence of the shims the same...
inner outer what happens
0mm 0mm Example standard setup
0mm 1mm Camber raise increase, roll center drops
1mm 2mm Camber raise stays the same roll center drops
Please feel free to correct, as I have written with out the roll center chart for the 416
Toughbeard is offline
Old 07-07-2008, 01:13 PM
  #2488
Rogier's Avatar
Originally Posted by habis
use the white delrin ones fro the 415.
you can get them at rcmarket.
The metal ones you cant get in parts....
Have any of you guys already tried this? Other 416 drivers told me they won't fit. Did you had any kind of modification to fit them on a Tamiya 416 spool??
Rogier is offline
Old 07-07-2008, 01:59 PM
  #2489
TryHard's Avatar
The outdrives should fit on the spool. But I wonder how well the sleeves will fit...
TryHard is offline
Old 07-07-2008, 04:05 PM
  #2490
They are both very capable cars. It seems the ta05ms is more capable with stock and 19t racing, and on technical circuits. The 416 is better for mod racing. The reason why the ta05ms is so popular is that the majority of clubs in Japan are small indoor circuits. Hence the success of the car.
As is always the case, depending on driving ability and style the generalisation above will have exceptions.
Its surprising to see that the 416 has already been discontinued, (see the tamiya usa site) maybe there will be a new version out soon.
Qatmix is offline
