Tamiya TRF416 / TRF416WE / TRF416X
#2446
I use Schumacher gold turnbuckles for the steering
The gold matches the hinge pins
#2448
#2449
http://www.racing-cars.com/products.asp?recnumber=2177
Never had a problem with them, and ive hit stuff hard
#2450
I noticed this yesterday, with DD on the front the track width is equal to the rear, so adding spacers means you're running a wider front than rear track width. Not saying it doesnt work but I always thought that was a no no.
I've also found from experience that the middle hole on the rear bulkhead causes the rear to snap oversteer mid corner when running outdoors on concrete
#2453
hehe...
Stock setup is B/A Front, and XB/D Rear, with long arms...
Now bear in mind that the pin widths on the Long arms are 54.5 and 55.5 F & R respectively. With the short arms they are 53 and 54.5 respectively... so you narrow the front by 3mm and the rear by 2mm, simply by mounting the short arms. Pic below shows two tables (one for front, one for rear), with what the difference is with the different block combo's and arms. In fact running D/D Short on the front will still give you a narrower front than if you were running kit setup... Bear in mind the numbers are for the outer hinge pin width (not the car width), but they still give an idea of how the car width will change.
HiH
Ed
HiH
Ed
#2454
What turnbuckles are people using for steering? I bent one of the aluminium ones the other night and was thinking of putting some other steer or titanium ones in, preferably blue
edit: think I found the ones I'll use
http://www.rcmart.com/catalog/rc-tam...th=595_744_712
for steering i use the tamiya DT-02 42mm steel turnbuckles. never had any one break and they look super cool in black/blue
#2455
hehe...
HiH
Ed
HiH
Ed
#2457
#2459
Forget the plastic things
I use the TAO5 steel outdrives.
Though its best if you use the steel driveshafts with them aswell, otherwise you'll be shearing driveshafts.
If you cant find them let me know
