Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 06-30-2008, 01:36 PM
  #2431
Rogier's Avatar
Originally Posted by RC MARKET
some sus. mount 1X -1E was arrived la !
44mm Swing shafts
trf416 diff set
F & R belt ...
Aren't this just the 'regular' 415 blocks and not the new style 416's??
Rogier is offline
Old 06-30-2008, 01:38 PM
  #2432
RC MARKET's Avatar
Same New TRF416 suspension mount !
RC MARKET is offline
Old 06-30-2008, 02:02 PM
  #2433
Rogier's Avatar
When will the 1c be on stock again...
Rogier is offline
Old 06-30-2008, 02:44 PM
  #2434
RC MARKET's Avatar
Sorry please check our web site ,
because i'm upgrade my PC now !
Old 06-30-2008, 03:16 PM
  #2435
Default re
They are home made LOL. Marc was colouring everything he could get his hands on at Reedy with his sweet "tamiya blue" shapie marker .
As for the upper decks, i have tried takin the rear bridge part out a while back in preperation for Reedy. I found the car to have a little more grip/consistency but when at reedy i eventually switched back as my car was not transitioning very well through the shicanes! For low grip situations it works well.
TRFwhitey is offline
Old 06-30-2008, 04:38 PM
  #2436
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Hebiki
question.. why are you guys lying the rear shocks down so far? and what effect does it have on entry/mid/exit steering? id like to try it out next im at the track and see what happens. (also try the raising the rear camber links next time im out). thanks guys!
Lying the shocks down makes the spring more progressive, so there will be a more gradual retardation of roll through the corner. Upright shocks do the opposite, they will roll a little at first but then resist the roll more abbruptly making the car feel more responsive but ultimately having less grip
CraigM is offline
Old 07-01-2008, 06:35 AM
  #2437
steveonamission's Avatar
Just like to say congrats to Tamiya for making a brilliant handerling car.
Dialled!
Basically run the DHI CUP Setup everywhere, with a few minor tweeks outdoors.
*Thumbs up*
steveonamission is offline
Old 07-01-2008, 08:46 AM
  #2438
AWK
AWK's Avatar
So I have finally given up on my TA05MS and decided to buy a 416 for the 13.5 class. Does anyone have any experience with this kit, and a 13.5 on asphalt with a good starting setup? Come on hebiki...I know you got something for me!
AWK is offline
Old 07-01-2008, 09:28 AM
  #2439
Front
Middle hole on Tower
Tamiya 400 Wt 3 hole pistons
3.5mm under camber link in middle hole
Furthest hole on A arm
4mm hex hub .5mm spacer
416 D front and 416 d rear flat
Tamiya White
5mm ackerman
.5mm bump steer spacer
Droop 6
Arm spacing 2 mm front 2mm rear
Rear
3rd hole out on tower
Tamiya 400 wt 3 hole pistons
3.5mm under camber link middle hole
3mm spacer outside hole rear hub
Tamiya Blue
2nd hole outside on a arm
4mm hex hubs
1xa rear front 1d rear
Arm spacing 3mm front 1mm rear
Its works
Old 07-01-2008, 09:29 AM
  #2440
Thats with a spool by the way
Old 07-01-2008, 11:13 PM
  #2441
CraigM's Avatar
Originally Posted by steveonamission
Front
Tamiya White
5mm ackerman
Droop 6
Rear
Tamiya Blue
4mm hex hubs
Its works
I noticed this yesterday, with DD on the front the track width is equal to the rear, so adding spacers means you're running a wider front than rear track width. Not saying it doesnt work but I always thought that was a no no.
I've also found from experience that the middle hole on the rear bulkhead causes the rear to snap oversteer mid corner when running outdoors on concrete
CraigM is offline
Old 07-02-2008, 12:44 AM
  #2442
syndr0me's Avatar
Trader Rating: 32 (100%+)
So the DHI setup is working pretty well for mere mortals? Are you guys changing much when you run it with a one-way, and slower motors?
syndr0me is offline
Old 07-02-2008, 02:39 AM
  #2443
Hebiki's Avatar
Trader Rating: 26 (100%+)
Saturday or PM me. i have a pretty good set up for tamiya. and im still refining my BCR set up
Hebiki is offline
Old 07-02-2008, 04:27 AM
  #2444
CraigM's Avatar
I'd just back the ackerman off to 3mm to run a one way
CraigM is offline
Old 07-02-2008, 04:55 AM
  #2445
CraigM's Avatar
What turnbuckles are people using for steering? I bent one of the aluminium ones the other night and was thinking of putting some other steer or titanium ones in, preferably blue
edit: think I found the ones I'll use
http://www.rcmart.com/catalog/rc-tam...th=595_744_712
CraigM is offline
