Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 06-28-2008, 04:23 PM
  #2416
syndr0me's Avatar
Trader Rating: 32 (100%+)
http://www.redrc.net/2008/06/exclusi...rally-rdx-phi/
Anybody know where I can get those dialed black toe blocks?
syndr0me is offline
Old 06-29-2008, 04:48 AM
  #2417
CraigM's Avatar
Trader Rating: 34 (100%+)
I asked this question a few pages back but I think it got a bit lost...
what effect does using more spacers under the rear camber links have? I understand what effect changing the angle has on roll centre but many of the setups I've seen use around 3mm under both sides of the link & don't understand what this does when compared to the kits .5mm under each side
CraigM is offline
Old 06-29-2008, 11:00 AM
  #2418
TryHard's Avatar
David Spashett originally gave me the idea to try this on the 415 (raise the rear link up). He said that it helped to smooth out the rear of the car, and make it less snappy, which was useful for carpet. You know what, he was right....
Or to be a bit more scientific...It does alter the roll centre and camber characterisrtics. On the 415, adding 1mm under the inner link lowered the RC by about ~0.6mm, whereas adding 1mm under the outer link lowered it by ~0.8mm. Effectively, the outer adjustment is coarser than the inner. I haven't measured the same on the 416 yet, but it is not hugely different to the 415 in terms of geometry, so they will probably similar there.
Also moving the links up will alter how the camber changes through the suspension being compressed. Haven't figured that one out in my head yet (although my guess is it helps reduce the amount of change).
HiH
Ed
TryHard is offline
Old 06-29-2008, 11:11 AM
  #2419
RC MARKET's Avatar
Tamiya new blue spring ?
Attached Thumbnails Tamiya TRF416 / TRF416WE / TRF416X-sat-1marcrheinard416-2.jpg   Tamiya TRF416 / TRF416WE / TRF416X-sat-1marcrheinard416-3.jpg
RC MARKET is offline
Old 06-29-2008, 03:09 PM
  #2420
Vicko's Avatar
Trader Rating: 14 (100%+)
hey I'm goin to racing an TCS race with my 416. anyone
out there got an set up for tamyia tires and 10.5 on an med. traction parking
lot track? oh ya with an tamyia body also, man this goin to intersting
Vicko is offline
Old 06-29-2008, 08:53 PM
  #2421
Check out the top deck, both the steering screw is not in there, and it looks like the rear portion has been cut accross at the webbing.
Besercoe is offline
Old 06-29-2008, 09:51 PM
  #2422
CraigM's Avatar
HiH
Ed
legend, thanks for that Ed!
the Hupo H reedy race setup is pretty good for those conditions though I went to XA/E at the rear
CraigM is offline
Old 06-30-2008, 12:46 AM
  #2423
Hebiki's Avatar
Trader Rating: 26 (100%+)
i tried this too with the steering. i flipped mine upside down..and screwed it back in. i thought about cutting that piece off the rear portion of the upper deck to increase flex. but i dont wanna spend $$ on another upper deck just in case it doesnt work.
Hebiki is offline
Old 06-30-2008, 03:06 AM
  #2424
sakaguchinet's Avatar
Hello,
just back from the ETS Race from Andernach. I am so happy got to the Stock A-Main. The car was awesome to drive. Unfortunalety I have realized it too late, that laying dampers on the rear would be the right thing.
Marc was using a new motormount plate, which was reinforced (bending with a 3.5T motor is a possible problem). The setups of all 416 were neraly the same (also Mod or Stock). Here you can see my setup:
http://sakaguchinet.dyndns.org/sites..._sakaguchi.jpg
The "Topdeckwithoutscrew" modification was very nice to drive (especially when the track had no grip). Nearly everyone used it. Some drivers (me too) have cut the steering post a little bit down, to avoid touching the topdeck.
sakaguchinet is offline
Old 06-30-2008, 06:56 AM
  #2425
RC MARKET's Avatar
Originally Posted by Hebiki
syndrome... with my experience.. you'll need at least the following:
Qty - block
2 - 1A
2 - 1B
2 - 1C
2 - 1D
1 - 1XA
1 - 1XB
1 - 1E
looks like they have a "1F" for those that want to widen the stance using the evoV short arms. ive always used the "1A" up front as a bridge.. with 1D. some setups ive seen now have 1B/1B up front.. or 1C/1C.
ive used a very narrow set up too using the 1XD.. but that was on asphalt.
some sus. mount 1X -1E was arrived la !
44mm Swing shafts
trf416 diff set
F & R belt ...
Attached Thumbnails Tamiya TRF416 / TRF416WE / TRF416X-ta-51342.jpg   Tamiya TRF416 / TRF416WE / TRF416X-ta-51344.jpg   Tamiya TRF416 / TRF416WE / TRF416X-ta-54068.jpg   Tamiya TRF416 / TRF416WE / TRF416X-ta-54073.jpg   Tamiya TRF416 / TRF416WE / TRF416X-ta-54078.jpg
Old 06-30-2008, 06:59 AM
  #2426
RC MARKET's Avatar
upper deck also not have screw !
Old 06-30-2008, 11:51 AM
  #2427
habis's Avatar
Dai, congratulations on your A-Main
looking at the weight blocks, that also are blue, i think the blue springs are "homemade"
habis is offline
Old 06-30-2008, 11:59 AM
  #2428
C van der Hagen's Avatar
44mm Swing shafts
trf416 diff set
F & R belt ...
When will the 1F suspension mount arrive?
C van der Hagen is offline
Old 06-30-2008, 12:22 PM
  #2429
RC MARKET's Avatar
We was order all new items ,
but only these items arrived !
Old 06-30-2008, 12:32 PM
  #2430
Hebiki's Avatar
question.. why are you guys lying the rear shocks down so far? and what effect does it have on entry/mid/exit steering? id like to try it out next im at the track and see what happens. (also try the raising the rear camber links next time im out). thanks guys!
Hebiki is offline
