Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 05-07-2008, 06:27 AM
  #2116
TryHard's Avatar
Originally Posted by Eirik
Faster laptimes!!
The car has more grip, and is all round more responsive...
TryHard is offline
Old 05-07-2008, 06:30 AM
  #2117
t4m1y4niac's Avatar
if using short arms...should i change another parts????
t4m1y4niac is offline
Old 05-07-2008, 06:45 AM
  #2118
Eirik's Avatar
Use wider front blocks, such as D-D or C-C, thats it
Eirik is offline
Old 05-07-2008, 12:53 PM
  #2119
RC MARKET's Avatar
So near many customer buy Sus. mount & short arm !
RC MARKET is offline
Old 05-07-2008, 08:52 PM
  #2120
fadzli's Avatar
front and rear short arm.. is it the same? D-D or CC for front or rear?
fadzli is offline
Old 05-07-2008, 08:58 PM
  #2121
veecee's Avatar
Trader Rating: 34 (100%+)
That is for the front. For the rear with short arms start with XA-E.
veecee is offline
Old 05-08-2008, 05:13 AM
  #2122
CraigM's Avatar
What setup changes did you guys make going from 1-way to spool?
CraigM is offline
Old 05-08-2008, 06:18 AM
  #2123
TryHard's Avatar
At the moment, very little!
I tend to prefer a bit of front arm sweep when running a spool, so have been using D/C on the front of my car... But I'm going to try C/C and C/B this weekend... when I get to race for the first time in months!
TryHard is offline
Old 05-08-2008, 06:55 AM
  #2124
bmmer701's Avatar
Trader Rating: 17 (100%+)
just want to ask when you said d/c. front front is D and front rear is C? is that right? thanks
bmmer701 is offline
Old 05-08-2008, 09:06 AM
  #2125
Stein Tumert's Avatar
Yes, then you get the "sweep" Ed mentions
Stein Tumert is offline
Old 05-08-2008, 04:19 PM
  #2126
CraigM's Avatar
Makes sense. With the nitros we usually run different ackerman so I've gone to 5mm behind the steering balls instead of the kit 3mm so I'll add some sweep and see how it goes
I haven't actually ran my 416 yet, I really need to get onto that
CraigM is offline
Old 05-09-2008, 05:07 AM
  #2127
Default Have setup sheet 416 in warm up world ?
have setup sheet marc or viktor ? in warm up world in Thailand
mamaa is offline
Old 05-09-2008, 05:33 AM
  #2128
pug 205 gti's Avatar
MR ED can you help im after some of these Tamiya 53640 5mm Blue Alloy Ball Nuts.ive tryed demon but none in stock!
I only need 4 because ive bought a losi shock,
and the ones that come with it arent the right sizes.
if you have some spare can i buy them?i will pay straight away using paypal
hope you can help gary
pug 205 gti is offline
Old 05-10-2008, 04:45 AM
  #2129
fadzli's Avatar
standard for rear is 1xb, d....
anybody use, xa with d? and short arm? it is 2.5 degree toe angle... what is the result?
fadzli is offline
Old 05-10-2008, 07:31 AM
  #2130
veecee's Avatar
Less rear toe-in will give you less rear traction. You could start with XA-E with short arms as I stated previously.
veecee is offline
