Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 04-22-2008, 12:43 AM
  #1966
bigbutstupid's Avatar
hey guys, im here asking for help how to improve my lap time. i've just bought a new lap timer and waiting for weekend to approach to test it out. my lap time and consistancy have been improving for the past 3 months and im always 0.8-1second behind the first place (fastest guy usually ~22.6sec).. i usually come in 2nd 3rd or 4th and sometimes but rarely 1st in qualifying rounds during club day. on the straights, im pretty confident that im the quickest but when it comes to conering, im very much slower. over here we run on asphalt, 19t and all of us runs komodo dragon pro spec.
any suggestions on how to improve lap time?
im thinking if getting a better servo would acutally help?
im currently using futaba s9401 and its close to 6 years old now. im looking at getting the new futaba BLS451.
ill try posting up my setup in a sec but at the moment at work. so i cant
bigbutstupid is offline
Old 04-22-2008, 12:55 AM
  #1967
fadzli's Avatar
Originally Posted by bboy
I see a lot of 416 coming out for sale in the second hand market. I wonder what is wrong since I like the car. Anyone has any idea(s)?
same here in my country. maybe because they dont perform locally... i cant say much because i am new. hope this therad can help 416 driver to improve anywhere...
fadzli is offline
Old 04-22-2008, 08:32 AM
  #1968
Stein Tumert's Avatar
From my experience this has more to do with your driving skills and setup than steering servo.... (but of course your servo needs to function OK)
Stein Tumert is offline
Old 04-22-2008, 03:49 PM
  #1969
mike ivy's Avatar
Trader Rating: 51 (100%+)
Jimmy Mac ygpm question for ya
mike ivy is offline
Old 04-22-2008, 11:52 PM
  #1970
CraigM's Avatar
Trader Rating: 34 (100%+)
Does anyone (e.g. rcmarket?) know if the white and milky blue spring sets and black and milky blue sway bars have been discontinued? That's the word I've got, but I'm not sure about the standard colours. I guess updated versions are coming
Looks like I've found a kit and the majority of the parts on Ed's page though
CraigM is offline
Old 04-23-2008, 01:02 AM
  #1971
TryHard's Avatar
Pretty sure you can still get the milky blue springs and bars (it's what I use, as I like it all to match... ), not sure on the white springs, or black roll bars.
HiH
Ed
TryHard is offline
Old 04-23-2008, 01:13 AM
  #1972
CraigM's Avatar
HiH
Ed
yeah thats my second choice. I wanted white springs with black roll bars because "milky blue" is a little fruity for an item as tuff and manly as roll bars. Matching is paramount though, are the regular springs all different colours or are they just silver?
Hey Ed just to confirm, the 46mm steel front shafts fit with the short arms? I'll be running a spool in mod so want to toss the aluminium shafts right from the word go, not much point if they bind up with the short arms though
CraigM is offline
Old 04-23-2008, 02:42 AM
  #1973
JimmyMac's Avatar
I have used 46mm steel bones with A/A blocks up front with short arms. But now I'm running B/B. Gonna switch to A/C and see how that goes. So yes... 46mm does work up front with a spool.
JimmyMac is offline
Old 04-23-2008, 03:04 AM
  #1974
TryHard's Avatar
As Mike said, yup the 46mm bones fit fine. With B/A on the front I had no clearance/binding issues, even with the one-way. With the spool the clearance is even better for the pins.
The regular springs are all different colours. Red is soft (11.9lb), yellow is medium (13.3lb), Blue is hard (14.0lb), white is extra hard (15.3lb), Grey is super hard (20.9lb), and purple is ultra hard (22.7lb). The milky blue and white sets are the same springs (although they don't include teh purple and grey), and all the same colour, with a dot on each spring distinguishing it's rating.
HiH
Ed
TryHard is offline
Old 04-23-2008, 03:49 AM
  #1975
CraigM's Avatar
Wicked. Ok this is what I ordered
TRF416
On Road Tuned Spring Set (x2)
TA05 Stabilizer Set
Sus Mounts 1XA, 1X, 1C, 1D, 1E + suspension block spacers 0.5mm/1mm
Front Direct Coupling + Front One-Way Pulley (37T)
Short Reversible sus arm (x2)
46mm Swing Shaft
And I'll grab the titanium screw set and alloy c hubs/rear uprights soon for added bling.
Thanks for all your help guys
CraigM is offline
Old 04-23-2008, 08:19 AM
  #1976
Travis S's Avatar
Trader Rating: 46 (100%+)
TRF416
TA05 Stabilizer Set
46mm Swing Shaft
I would get the c hubs now. That is the weakest point of the car. I broke mine the 2nd time on the track on minor hit... I had to wait 3 weeks before I could get a spare since they couldn't be found anywhere! I went aluminum and have yet to have a problem.
Travis S is offline
Old 04-23-2008, 08:40 AM
  #1977
syndr0me's Avatar
Trader Rating: 32 (100%+)
In my humble opinion, the 416 should have the following before hitting the track:
Stronger bumper (PDub here)
Aluminum chubs (Square)
Steel CVD's (up front at least)
Titanium steering rods
Also, be sure to loctite all the steering assembly screws, they will work loose no matter how hard to tighten them. I've been using the blue aluminum tie rods on the rest of the car without any trouble so far. I've got the full set of titanium just in case, though.
syndr0me is offline
Old 04-23-2008, 11:05 PM
  #1978
sakaguchinet's Avatar
Default Square Rear Hubs
Hello,
finally SQUARE will release on 12/05 the new Aluminum Rear Hubs with 0 of toein in blue hard-anodized aluminum. Think they will be available in europe around 16/05.
More news will be uploaded tomorrow under: http://www.rc-square.de/english/square_1_1_news.htm
sakaguchinet is offline
Old 04-24-2008, 10:13 AM
  #1979
gents, can i use 416's front spool or one-way on 415 msx?
Molala3 is offline
Old 04-24-2008, 10:30 AM
  #1980
mac853's Avatar
I don't see could do that, but why don't use the properly for 415msx?
Earlier times the problem was 416 couldn't have a own spool instead of try using 415mre ones.
mac853 is offline
