Tamiya TRF416 / TRF416WE / TRF416X
#1921
hi jilles, welcome back and looking forward to the sheets.
#1922
I'm not sure if it'll be a good idea. It's only a good idea if they use a different ball stud than what's in the kit. The only ball stud that is affected is the one you show. There is a short version of that ball stud that matches the hex head ball stud screw thing-a-majaber's height. If you are worried about strength, go for the steel hex heads. Just curious, but why are you using the ball nuts instead of the hex heads?
#1924
I still use the hex head too for inner if I use 3mm shim.
Welcome back Jilles!
#1925
2.5mm lower deck coming.
TRF416 ロワデッキ2.5mm厚(RC限定)
#1926
#1927
#1929
Just been window shopping round the world and came accross these little beauties.I,m guessing some of you may have already seen them so this is for those who havent.They are tamiyas 6 spoke set upwheels drapped in the finest blue anodizing that only tamiya do best! they will help setup and add the bling to the pit table.heres a link. http://shopping.rcmodel.hk/product_i...oducts_id=6538
#1930
any comments on why Tamiya would be releasing a 2,5mm chassis when the 2,25mm has shown so great result on indoor carpet/rubber?
#1931
I race the 416 on asphalt and I noticed since the first time I put the car on the track that it has too much flex. Releasing a 2.5mm chassis is a very good move and I will convert as soon as it's out!! A 2.5mm chassis will stay flatter and not lean like this 2.25 is. Don't get me wrong, this car is absolutely on point, but this will make the car even better.
Also, since I don't post much on this thread, I wanted to mention how good this diff is. I've run a 4.5 and a 10.5 in this car and the diff holds up to all conditions. It doesen't back off or get gritty at all. It's undeniably smooth and takes off out of the corners like a sling shot. Best diff on the market period.
#1932
The 2.5 chassis is good on higher bite carpet, but i have found the flex of the 2.25 helps in low grip or on asphalt. Last year at reedy i used a 2mm and it was great! I have actually used black rubber o-rings under my upper deck to get the car to flex more at my local track. It was a little more "loppy" but very consistent and provided great traction. Keep in mind this was only for low grip situations, such as the begining of a night racing or new carpet. I had even noticed in one of the pics from the last event Viktor had removed the steering post brace to get a little more flex out of the car.
#1933
i want to change from nimh to lipo but i dont have the tool to weight the battery. onybody know the weight of this?
6 side by side IB 4200 soldered
6 side by side Enrich power 4600 soldered
4800 platinum orion lipo
any lipo brand with known weight?
make this this comparison to make sure how much extra weight to add...
an to which side.
this info will be usefull to all. tq.
an to which side.
#1934
an to which side.
an to which side.
The Team Orion 4800 Li-Po pack weighs 258g, versus 401 g for NiMH 7.2 volt assembled cells. This is 36% lighter!
The 3200 weight even less at 198g, this is less then half the wieght of a 4200mAh Ni-MH stick pack yet provides the same run time!
Personally, I would go for a Orion 3600 or Schumacher Core 5000 pack over the 4800... the 4800 is a little bit of old tech now (if it can be called that
HiH
Ed
#1935
