Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 04-16-2008, 03:12 AM
  #1906
Eirik's Avatar
Originally Posted by TryHard
I've been trying to get hold of the TITC and LRP setups... so far no joy
As for my other hobby... some pics attached. I'm far left in the first one (Can just see the face with sunnys on), in the red top in the second (yup, showing my arse), and far right in the third (black and white top)... it's a bit more active than RC, but just a tweaky
Ed
Hey Ed,
I got them yesterday, but I forgot to bring them to work for scanning.
I will try to remember them tomorrow.... Sorry!
It was nothing special though, very standard setups.
Eirik is offline
Old 04-16-2008, 03:20 AM
  #1907
Hi Eirik, do you also have the setup from Tamiya guys at the ETS this weekend?
It seems that it is a little bit different with white/blue spring as we usually run indoor so it should be interesting to see it if possible!!
Thanks for your help
canto54 is offline
Old 04-16-2008, 03:25 AM
  #1908
TryHard's Avatar
Originally Posted by Eirik
Hey Ed,
Excellent
Tried to send you an email via my work address today, got bounced back both times.... no worry, was only asking about the sheets
Ta
Ed
TryHard is offline
Old 04-16-2008, 03:51 AM
  #1909
JimmyMac's Avatar
Nice hobby Ed! I can see why you hang up rc racing for the summer! I know I would! Love the ocean! Much more exciting! I think after the Nats in June I might take a short break and hang out with my dad. Do some underwater treasure hunting on the coast for a few months. Next year when he starts to collect on his social security he's gonna put his boat back in the ocean. We'll putt around looking for sunken ships. It's an old dream of his. Should be fun!
Well post up the setups! I'd like to compare some info on them.
JimmyMac is offline
Old 04-16-2008, 04:28 AM
  #1910
CraigM's Avatar
Trader Rating: 34 (100%+)
Jeez there is awesome support in this thread, you guys are a wealth of knowledge! If anyone can get their hands on a setup from the last ETS round that would be unreal, we only really race on asphalt with rubbers down here in Oz and I'd like to build my 416 with a good rubber setup from the get go
CraigM is offline
Old 04-16-2008, 06:01 AM
  #1911
veecee's Avatar
Good to see you getting a real car mate. The 416 works very well at Tempe. Make sure you get some short EVO4 arms and build the kit with them.
veecee is offline
Old 04-16-2008, 06:09 AM
  #1912
fadzli's Avatar
Originally Posted by JimmyMac
Try some kick up. It helps my car gain some steering in the fast long corners. Start off with .5mm kick up.
what u meant for kick up???? help me to understand that term. tq.
fadzli is offline
Old 04-16-2008, 06:32 AM
  #1913
RC MARKET's Avatar
MAY release 2.5mm lower deck !
RC MARKET is offline
Old 04-16-2008, 06:40 AM
  #1914
Eirik's Avatar
They use the White/Blue springs outdoors all the time now
The setups are very similar outdoors and inndoors now, and that is a really good thing
Eirik is offline
Old 04-16-2008, 06:49 AM
  #1915
I'm not sure what Marc and Viktor ran but Jilles used blue springs front and yellow rear for most of the event. He also tried running progressive springs of similar basic rates but that did not have a big effect. Note that on the MACH track the Jaco 32 tyres with pink inserts did not give a lot of grip so the softer springs were used to help generate grip.
As a starting point for outdoors I suggest using the DHI/LRP Masters setup as the base. From there work with small changes to improve the setup. That is what the team was doing in The Netherlands as well.
tonyv is offline
Old 04-16-2008, 10:46 AM
  #1916
Hebiki's Avatar
Trader Rating: 26 (100%+)
TonyV... werent you with Team XRay before? when'd you switch?
Hebiki is offline
Old 04-16-2008, 12:13 PM
  #1917
JimmyMac's Avatar
Kick up. The front suspension is angled up towards the front. Place a 0.5mm shim under the front/front suspension block. Just try it out one round or during practice. Just remember to reset/check your droop, ride height, camber, and front toe when you do. Caster is slightly increased. With this setup. Maybe you call this Pro-dive? Just another term for kick up.
JimmyMac is offline
Old 04-16-2008, 12:20 PM
  #1918
Yes I was. But after 7 years it started to feel too much like work and not enough like the hobby I enjoy so much so decided to become a privateer again. The choice for Tamiya was easy as it is the one car I allways wanted to try. It is allways driveable no matter what the circumstances. And with Jilles moving...
Don't get me wrong, the XRay T2'008 is a great car too, especially outdoors. But I haven't had a reason to regret going for the TRF416 yet.
tonyv is offline
Old 04-16-2008, 12:48 PM
  #1919
JGH
Hello guys,
It's been a while but I will help you guys out as much as possible. As soon my scanner will work I will post my set-up's from both LRP masters and ETS in Heemstede. Both set-up's are almost identical to what Marc and Viktor ran.
Jilles
JGH is offline
Old 04-16-2008, 03:00 PM
  #1920
TryHard's Avatar
Brilliant, cheers Jilles.
Congrats on round 3 at the ETS. It's appreciated that you take the time out to post up on here
TryHard is offline
