Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 04-06-2008, 08:34 PM
  #1831
syndr0me's Avatar
Trader Rating: 32 (100%+)
Thanks man, I'll give it a shot. We're running 10.5's on parking lots that are swept and sugared, but still pretty slippery. It's also still kinda cold. I plan on running next time, I didn't have one to try today.
I don't know if the car or the tires or the track were the problem, but something wasn't right. I didn't really start with any specific setup (close to the kit for carpet) so I'm not looking to improve what I've got now, just start somewhere that's in the ballpark so I can work my way up. I've only got the stock suspension parts at the moment.
syndr0me is offline
Old 04-06-2008, 08:39 PM
  #1832
JimmyMac's Avatar
You running oneway?
JimmyMac is offline
Old 04-06-2008, 08:50 PM
  #1833
syndr0me's Avatar
Originally Posted by JimmyMac View Post
You running oneway?
I did today... it seemed to feel better than a front diff. It sucked all around, though, I was losing time everywhere. It seemed like a spool was really needed... among other things.
syndr0me is offline
Old 04-06-2008, 08:54 PM
  #1834
JimmyMac's Avatar
That might be your main problem. Get a spool when you can. With a oneway in a parking lot, you need to be as smooth as you can. Don't try my setup with a oneway... But you can try the diff if you want.
JimmyMac is offline
Old 04-06-2008, 09:06 PM
  #1835
syndr0me's Avatar
Yeah, makes sense, the car was nearly impossible to drive when I finally got softer tires on it. It turned in great, but was so loose and unpredictable, it was giving me fits.
So, if I'm wanting to order a spool, I'll need:
49493 (Direct Coupling) [link]
54023 (One-Way Pulley) [link]
What about spares? In looking at this picture, is it the black pieces that normally break, or those and the aluminum sleeves? What are the names and part numbers of those pieces?
syndr0me is offline
Old 04-06-2008, 10:03 PM
  #1836
JimmyMac's Avatar
I've never busted an aluminum sleeve. The delrin ones on the 415 were very hard to bust. Would have to be a bad wreck that rips the arm off to really tear up a delrin outdrive. The aluminum sleeve does an excellent job of strengthening them up. Not sure if the old white ones will work with the new spool. But would be a good idea to pick up a few sets when they become available. But yeah, those are the correct parts.
JimmyMac is offline
Old 04-06-2008, 10:08 PM
  #1837
syndr0me's Avatar
Cool, thanks for the help. I need to redeem myself after the abuse I took today. :-)
syndr0me is offline
Old 04-07-2008, 01:05 AM
  #1838
miccal's Avatar
Trader Rating: 23 (100%+)
Okay, now I am at home I can check the individual weight of things.
Body - 104 grams
Wheels and tyres - 115 grams
IB4600 6 cell battery - 456 grams
TRF416 without wheels and battery - 910 grams
Total race ready - 1590
That is without a transponder and with an uncharged battery.
As I said, the car is stock standard except for LWT arms, steel swing shafts front and rear and a spool. The Futaba s9551 is as light as the s9550.
Originally Posted by miccal View Post
I am using a Novak GTB and SS13.5, a Futaba s9551 and a standard size Futaba receiver in my TRF416, everything else is stock standard. The car weighs in at 1630 grams, how can I lighten it up? How much weight saving does the titanium and aluminum screw set give you? Any comments and ideas are welcome.
My body weights about 110 grams, so that is not it. I use IB4600 6 cell packs, LWT arms, steel swingshafts and a spool. I am under the impression that the Novak GTB/SS13.5 system is heavier than others. Lipo is not an option for me, they are not allowed as yet.
miccal is offline
Old 04-07-2008, 04:18 AM
  #1839
m3ndo5a's Avatar
Jimmy's Parking lot set up was pretty strong...He change his ackerman plus some other things and was quick around the sweeper(Stronger throttle hold). He think it was too aggressive but from my veiw the was very smooth and the transition was nice. Although I was running the Ray08, which is quicker on 180's and chicanes the Changes Jimmy made took way the Ray08 advantage. It came down to power, which once again Jimmy had the upper hand....his car accelerate like a bottle rocket. I was too lazy the change a pinion gear, plus one downside I saw about Jimmy having a Lower FDR.......His battery dump quicker than mines??? which was weird....His 4.4FDR LRP vs my 4.7FDR SP GT. His battery drain 30% faster than mines.
LRP seem to be the stronger ESC as well, We both ran SP 13.5 demons.
Good job on your wrench work Jimmy. This guy knows the TRF416.
m3ndo5a is offline
Old 04-07-2008, 05:54 AM
  #1840
TryHard's Avatar
Just a quick pointer, my site is down at the moment.
I've had it jumped over to a different server type, so now need to upload it all back on. Thankfully I keep a working copy elsewhere, so won't take me very long to do
TryHard is offline
Old 04-07-2008, 11:34 AM
  #1841
RC MARKET's Avatar
TRF416 maybe have new ver. ( LRP Master ?? )
with Front spool & titanium Alum screw set .
not sure in this moment !
RC MARKET is offline
Old 04-07-2008, 02:55 PM
  #1842
pixs .. from http://tcm2008.lrp.cc/
Andyg01 is offline
Old 04-07-2008, 03:04 PM
  #1843
TryHard's Avatar
Well, I've got my site back up and working happily, and it also has it own new addition... it's own micro forum
Ok, so more than anything it's an excuse for me to have a play around with forum software (add that to the CV ), and in no way am I expecting much out of it, but if anyone fancies heading over and having a look, and letting me know your thoughts, well, would be greatly appreciated. I'm certainly not intending for it to take away any of the great info and help on here, thats for sure.
THard.co.uk Forum
Shame I'm not going to be racing for a while.... So many things I'm itching to try on my car, oh well
Cheers
Ed
TryHard is offline
Old 04-07-2008, 03:26 PM
  #1844
I tried the DHI cup Jilles setup on asphalt this past weekend and my car was really good. I was very impressed at how easy and smooth it was to drive but still had good steering. I used a spool but the car felt like it had a one-way. Very impressive. I can't wait until the next race
DOTMAN is offline
Old 04-07-2008, 03:47 PM
  #1845
bobbyvegas's Avatar
Nice looking machine! pics above..
May have to get one myself..
bobbyvegas is offline
