Old 05-12-2003, 12:28 PM   #1
doublest's Avatar
Send a message via MSN to doublest
Default Big Problem!!1
When i switch on my car and transmitter, (im tryin to set up my ESC) wen i turn left and right, the wheels shudder left and right and the rear wheels also move when i turn left or right.
What could this be. I also got Capacitors with my ESC do these have to be installed to the motor, ive installed the Schottky diode.
doublest is offline   Reply With Quote
Old 05-12-2003, 12:43 PM   #2
doublest's Avatar
Ok i sorted it,
But wots the little capcitors i got, do they need to be fitted, its all setup.
Old 05-12-2003, 01:33 PM   #3
doublest's Avatar
Default Just run the car
I didnt fit the capcitors and it runs fine.
One thing i want to ask is, wen i brake quite hard u hear a scraping sort of noise. Is this normal.
Old 05-12-2003, 03:19 PM   #4
CRASH's Avatar
Trader Rating: 26 (100%+)
Some motors come with Surface mount capacitors already installed on the motor. Some older motors do not have these and yes you have to install the capacitors on the motor. Or else you are likely to experience some glitching as you described earlier.
Later
CRASH is offline   Reply With Quote
Old 05-12-2003, 03:24 PM   #5
doublest's Avatar
Im running a Monster Stock dothe capacitors have to installed, i have run the car, didtn find no probs, if so where do they go.
Pics would help.
Old 05-12-2003, 03:48 PM   #6
c-lyon's Avatar
The MS has surface mount caps. You can see them on the green plate at the end of the endbell. If your ESC doesn't have reverse you might find a Schottky diode a help. Install either on the motor or on the wires within two inches of the motor, which saves getting one for each motor.
c-lyon is offline   Reply With Quote
Old 05-12-2003, 04:42 PM   #7
doublest's Avatar
I have the Revenge of the monster stock motor, does this have to have the Capacitors on, cos i do have the Schottky diode on.
THere wont be any dmamage if i dont use them will there.
If they do have to be installed, can some one show me where, but hope they dont lol
Old 05-13-2003, 09:34 AM   #8
popsracer's Avatar
Lightbulb doublest;
THE MONSTER STOCK ALREADY HAS SURFACE MOUNT CAPACITORS ON THE CIRCUIT BOARD. YOU DO NOT NEED TO INSTALL ANY MORE!!!!!
popsracer is offline   Reply With Quote
Old 05-13-2003, 02:01 PM   #9
doublest's Avatar
Thanks mate, all sorted, i werent gonna put them on anyway.
Cheers again.
ESC PROBLEM ghj1997 Electric Off-Road 13 06-04-2008 08:38 AM
Problem RaceANissan616 Nitro On-Road 20 07-23-2006 09:07 PM
KO PRO PO VSF-1 PROBLEM mazmo Australian Racing 4 07-24-2005 07:38 AM
New to R/C and I have a bit of a problem ZeeBMaN Rookie Zone 6 05-15-2003 05:08 AM
